- This topic has 168 replies, 12 voices, and was last updated 12 years ago by
January 28, 2014 at 11:06 pm #5542
darmic1ParticipantJanuary 28, 2014 at 11:08 pm #5544
darmic1ParticipantJanuary 29, 2014 at 5:16 am #5547
vhgmcbuddyMemberAre you going to use this in summer darren ? If so you will stop traffic in your street
January 29, 2014 at 9:50 am #5548
hillsiderParticipantIf it cuts grass as good as it looks it will be the best lawn in the neighbourhood.
February 2, 2014 at 12:40 pm #5636
darmic1ParticipantThanks guys, decided to try the engine today, pleased to say it started on the 3rd attempt and ran well. A bit smoky but then it is 2 stroke and I’ve got the fuel mixture somewhere near 20:1. Also the paint on the exhaust is curing and that smokes a fair bit!
Here’s the link https://youtu.be/5lSD2YKu6U8February 2, 2014 at 2:38 pm #5637
hillsiderParticipantLooking good, you will also get a bit of smoke from the various engine bolts and associated metalwork burning off assembly oil etc.
February 5, 2014 at 7:17 pm #5712
darmic1ParticipantFebruary 5, 2014 at 7:20 pm #5714
darmic1ParticipantFebruary 5, 2014 at 8:08 pm #5719andyfrost
ParticipantDarren , you are a credit to our movement , that looks stunning……..a huge well done.
February 6, 2014 at 5:06 pm #5729
darmic1ParticipantFebruary 6, 2014 at 6:39 pm #5738
vhgmcbuddyMembernice one. must be the best resto this year. thumbs up darren
February 8, 2014 at 6:07 pm #5765
darmic1ParticipantCheers John! I think there will be more, it is only February……….
February 9, 2014 at 7:57 pm #5797
darmic1ParticipantWas having a problem with the kick start pedal when trying to start the mower. The instructions clearly state not to let the pedal return un-checked as this could cause damage…… However with the aluminium having been worn completely smooth, my foot kept slipping off the pedal. I did consider using the Dremel to cut new grooves into the ally, but decided to glue some ‘non slip’ material to the pedal.
February 9, 2014 at 8:01 pm #5799
darmic1ParticipantFebruary 10, 2014 at 9:40 am #5809
charlieKeymasterAn excellent job. Just a small point, I think the id plate would have been black originally with the stamping showing bare metal.
