Home › Forums › The Main Forum Area › Projects › ATCO Groundsman 28 inch mower.
- This topic has 111 replies, 10 voices, and was last updated 11 years, 2 months ago by
January 2, 2014 at 5:40 pm #4744
Memberwell that’s a bridge I have to cross when it happens. QUESTION……would I be right in thinking Paraffin is as good a cleaner as any or what do the Pro’s recommend, baring in mind that when is dirty etc you dispose of it ?
January 2, 2014 at 6:03 pm #4749vhgmcbuddy
Memberparaffin is fine john
January 2, 2014 at 7:21 pm #4756darmic1
ParticipantMake sure the pump is suitable for the solvent/paraffin based cleaners, if its the sealey or clarke it should be fine……You can mix paraffin and solvent based cleaners to make it a bit cheaper. I do 50/50 mix. Dont buy the water based parts wash solution, I have about 20 litres of the clarke stuff, not much good!
January 3, 2014 at 2:33 pm #4792vhgmcbuddy
MemberAt last the rebuild has started,and taking lots of photo’s has paid off. the bolts which hold the mower handle bar framework are different lengths and pictures helped a lot with getting the main handles the right way around. will not be putting engine in at the moment because the total combined weight will be to heavy for me to manage safely as I had to bring her into the shed on its front rollers in a side ways manner. A hot tip needed to make the front and rear rollers look a lot newer than they are at present. all ideas considered as they look shabby THANKS.
January 3, 2014 at 4:51 pm #4804charlie
Keymasternigel, I have heard some stories about women trying to get a mans clothes off but that is a new one!!!!
January 3, 2014 at 7:26 pm #4812vhgmcbuddy
Memberfunny you should say that Charlie but I know a middle aged woman who gets turned on by the smell of old fashioned creosote. good job you cannot get it now without a licence, because she lives next door ha ha.
January 4, 2014 at 8:41 am #4835charlie
KeymasterI might have a drop in the shed if you would like some!!!
January 4, 2014 at 5:15 pm #4840vhgmcbuddy
Memberworks every time charlie 😀
January 5, 2014 at 1:29 pm #4893vhgmcbuddy
MemberThought I might as well get this clutch operating lever mounted as I am having to get parts down from my paint line to put up further components as the resto progresses. Looking at the end of the clutch coupling has reminded me that the original rubber sleeves which take up the initial torque of the engine at take off, have worn to such a degree that prompt attention is required. Will need three short lengths of say heater hose cut to 1 inch lengths to get things back to how it was back in the late 1950’s.
January 6, 2014 at 7:52 pm #4936vhgmcbuddy
MemberHandles on the mower when purchased where missing so,been the type to improvise I am making my own. Using the idea which is used on the Auto Culto Field Model L have bought some file handles and have split them long ways. Will then get some flat bar and mould the steel to the shape of the wood replacement handles. Giving me a special twist to the personalized hand grips. see photos below.
January 6, 2014 at 8:01 pm #4940darmic1
ParticipantThats a good idea! I take it the wood will remain either side of the steel?
January 6, 2014 at 8:04 pm #4941vhgmcbuddy
MemberYes Darren you have got it. have you seen the auto culto I did, it will be in projects in old forum.
January 6, 2014 at 8:11 pm #4942darmic1
ParticipantI think I have John, another of your fine resto’s! Will go have a memory refresh, whilst waiting for some paint to dry. Just gave the inside of my grass box a coat or two….
January 6, 2014 at 9:15 pm #4949darmic1
ParticipantJust revisited your Auto Culto project, nice old machine that! I dont know where you ‘park’ all your resto’s?
January 6, 2014 at 9:36 pm #4951vhgmcbuddy
MemberIts a secret the way of the world dictates this you know where im coming from.
