Home › Forums › The Main Forum Area › Projects › Ransomes MG2 #551
- This topic has 40 replies, 7 voices, and was last updated 9 years, 1 month ago by
joegrgraham.
April 22, 2016 at 8:08 pm #20654
joegrgrahamParticipantEvening all,
Thanks to all who have posted on my thread ‘Ransomes Tracks’ over in the machinery forum.
As this is going to be a protracted affair, I thought it best to let that thread go to bed and start one on here.
Just a quick recap.
I acquired 551 a couple of weeks ago, doing a swap for a dead Allis Chalmers that I was never going to get around to.
It drove onto the trailer, which was a good start!.
Subsequent fiddling revealed that the clutch is grabbing, one steering brake is a bit iffy, and a bit of general stiffness and rust.So, into the shed.
So far, the tracks are split and will require new rubbers and bolts, and the sprocket rollers are all seized.
As it is coming apart, it has been revealed that it is an older restoration, albeit with a brush-painted finish which has suffered with time.
The toolbox appears to be original, with the original brass plates screwed to it. The floor was rotten ply though.
Tonight, I made a start on the engine, removing the air cleaner, fuel tank, tank brackets and the fan. The only nasty surprise being some pigeon poo welding on the underside of the fan housing (am I right to think this is a weak spot? as the rest of the machine is pretty good for 76 years old).
I will try and get some pics of progress so far tomorrow.
At the moment, I’m trying to get it reduced in size as much as possible, because S.W.M.B.O’s parents are coming to stay in a few weeks time, and I will probably lose my shed for the duration, as all the stuff in the spare bedroom will be moved out there.
Hopefully over the weekend I will try and get the engine lifted off.
Joe.
April 23, 2016 at 4:19 pm #20655
joegrgrahamParticipantAfternoon everyone.
The family went shopping today, so i got a couple of very productive hours in on the MG2.
The original plan was to leave it alone cosmetically, however, due to it having had a poor repaint in the past, the fact I have to virtually strip it anyway, and the ease with which it is coming apart, I know that if I don’t repaint it, it will annoy me for ever more!! Plus, a friend has just bought a sand blaster…So today I have removed the engine, implement lift, drawbar, WC rollers and carrier and the rear idlers. Also numerous small bits and bobs.
Pics show progress so far.April 23, 2016 at 4:23 pm #20658
joegrgrahamParticipantApril 24, 2016 at 7:27 am #20663
charlieKeymasterMaking good progress.
April 24, 2016 at 9:03 am #20664
daveParticipantI am glad to see a workbench a bit like mine, a bit cluttered.
Good luck with the restoration. Dave.April 24, 2016 at 3:20 pm #20665
joegrgrahamParticipantAnd the sad thing Dave, is that the shed/bench is tidy!!!
A place for everything, its just that place is on the floor…..April 24, 2016 at 5:16 pm #20666
joegrgrahamParticipantApril 24, 2016 at 5:22 pm #20669
joegrgrahamParticipantApril 25, 2016 at 8:25 am #20673
charlieKeymasterNow you have top off gearbox you should be able to confirm date as it is stamped on one of the gears, crownwheel I think.
April 30, 2016 at 5:17 pm #20712
Made good progress on the MG this week.
Sand blaster has been pre-warned and all that remains attached to the tub is the gear assembly and the final drives.
Anyone have any tips how to remove the rear bearing retainer for the PTO? it is unbolted and rocking, just doesnt want to budge off the shaft.May 2, 2016 at 9:12 pm #20774
joegrgrahamParticipantI’m glad I decided to do a full strip-dow .
Got into the final drives tonight, and they clearly havent seen oil for a while!.
The left hand pinion gear is badly worn and the right hand bull gear fell off! Due to a seized bearing.
I would upload some pictures, but my phone has been misbehaving since I dropped it in wet concrete the other day!!May 4, 2016 at 8:23 pm #20802
joegrgrahamParticipantA bit more progress.
Only the gear assembly to go, just need to shift two very stuck brake band pins, and how do you get to the bottom bolts? There are brake drums in the way…..Found a couple of nasties, I dont think the pinion bearing retainer should look like THAT! (Pic 2). I think a bearing must have failed at some time, one fell apart on the other side and they’re all stiff, so I shall probably replace the lot.
Also, the hubs are badly worn where they exit the final drive case (pic 3) which I can see causing sealing issues.May 5, 2016 at 10:17 pm #20810expeatfarmer
ParticipantJoe the hub seal can be recovered by using a skim of plastic metal to fill the most severe wear, when you refit a new seal do not drive it fully home so that the lip of the seal is running on an unworn surface.
May 16, 2016 at 6:36 am #20920
joegrgrahamParticipantHi all,
Just a quick update on the Ransome’s.
Progress has been a little slow this week as I have been engaged in matters of Land Rover suspension, however yesterday I managed to get the gear assembly removed, so now the tub is completly stripped.
So now begins the tedious task of cleaning, wire brushing and paint stripping a large pile of bits!.(not to mention trying to scratch together a few pennies for new parts).
Very little will probably be done the next few weeks as I have in-laws arriving next weekend, and I still have to try and get the damned Trusty running again ready for Lotmead.August 13, 2016 at 5:26 pm #21905
joegrgrahamParticipantHi all.
It’s been a while, but the in-laws are gone, the shed move has been completed and the trusty is running.
So I can now do a bit on the ransomes!.
My man who will do the sand blasting is combining at the moment so in the meantime I have stated cleaning some of the gearbox parts.
With the crud removed, the number stamped into the gears is 580, the number on the id plate is 551, so has the plate been swapped or have the gears been changed? -
