Simar Rototiller plough mount
Home › Forums › The Main Forum Area › Projects › Simar Rototiller plough mount
Viewing 15 posts - 1 through 15 (of 38 total)
  • #33136
    knappster
    Rebuilding my Simar Rototiller just taken the plough mount off and made this mod to it drilled a small hole in the mounting plate fixed a large split pin in to hold a chain from the linch pin holding the plough on its mounting peg. Seemed a good idea so as not loose it if it comes unclipped a simple fix if you have this type of mount
    #33183
    knappster
    The old girl is coming together test run soon
    knappster
    Modified plough mount
    #33189
    Looks very nice, did you get that paint made up to your spec? I have a plough, so will be interested to see a picture of your modification, saw another machine for sale on that well known website, and it had a proper exhaust box fitted across the front, I think I understand why!
    #33190
    End of exhaust should be flattened and have slots cut into side see https://vhgmc.co.uk/photo-galleries/simar-imgsimar025/
    #33191
    knappster
    Hi Plonker
    Thanks for the interest, the paint was the closest I could find with out having it mixed, it is Buckingham Green byJohnstones looks okay when dry on the Simar. Hear is a photo of the plough hitch hope this helps
    roatavator
    Charlie. All the various SIMAR models with front exiting exhaust I’ve seen have the “usual “ stub exhaust. But many continental ones have large exhausts, sometimes a serpentine layout, incorporating exhaust boxes. Am I right in thinking they were SIMAR options or accessories? Perhaps they were available after market over here?
    #33198
    The only option I have seen for UK models is the large pepper pot, which I have on my model 35. The big model 90 did have an exhaust and silencer mounted alongside fuel tank and I have seen photos of model 60 with exhaust across the front.
    #33199
    knappster
    Thanks for the info chaps, I have seen photographs of the ones you are talking about I may try the UK version and press the one I have to form a fish tale and cut some slots in it and see how loud it is 😳
    #33200
    roatavator
    This is a typical continental exhaust.
    Drawings for the exhaust and silencer should be held in archives at MERL. I will need to check part numbers and see if they are on the list.
    #33274
    knappster
    Made a replica of the original exhaust for my Simar, something close to the original, have to see what it sounds like 😳
    roatavator
    Very nice job. What it will sound like? Answer: LOUD!!
    #33279
    knappster
    Ha ha yes as I thought, will get some ear defenders 😂
    #33303
    knappster
    Hey Guys help
    Can anyone give me the correct two stroke mix for my Simar, on the machine it says a mix of 6% for 5l of petrol that would be 300ml of oil 😳 that seems a lot am I reading this right ? Or is it for a full tank ? I am at a loss help
