Simar Rototiller plough mount
Home › Forums › The Main Forum Area › Projects › Simar Rototiller plough mount
Viewing 8 posts - 31 through 38 (of 38 total)
  • #33556
    That’s one fine looking SIMAR! Makes mine look shabby, but I don’t think I could achieve anything like your results. If it’s any consolation we’re at the end of the ploughing season now, fingers crossed it will be considered safe to be attending events come late summer.
    #33557
    Thanks for that my friend I still have work to do on her seems to be collecting a lot of fuel in the lower part of the engine which I have to drain before I can start her is this normal? Any advise would be welcome. Stay well and safe all of you
    Knappster
    #33558
    Thanks for the plug gap setting Charlie 👍
    #33559
    I always have to drain excess fuel from the crankcase before starting. I have found it will not start if I don’t.
    #33560
    Same here Charlie. I do find if you’ve just run the machine for a couple of minutes then there’s a lot more excess fuel than if it’s had a good hour or two of work. Normally after working it’s only a few drops of excess oil and no fuel. So if Knappster is just running the machine for a short time I’d say what he describes is not unusual.
    #33561
    Hi gents
    That sound good to me and reassuring to know my Simar is in line with others out there
    Again many thanks knappster
    #33565
    That the plough ready to go, when ever that is 😳
    #33669
    Hi everyone hope all is well with you guys, update on my Simar and plough, fitted a safety chain to the locking pin on the plough so I don’t loose it when if ever I can plough with her ! When ever that is 😳
    Keep safe Knappster
