Home › Forums › The Machinery Forums › Pedestrian operated machines › SImar A5
- This topic has 34 replies, 7 voices, and was last updated 9 years, 7 months ago by
roatavator.
April 18, 2016 at 1:20 pm #20573
roatavatorParticipantApril 18, 2016 at 3:16 pm #20576
charlieKeymasterserial number doe snot seem to fit in range on the information I have. A5 are 4 digit serial numbers, 623? would be correct circa 1029-30.
April 18, 2016 at 6:48 pm #20590
roatavatorParticipantSorry Charlie, I’ve now had a better look, its 6239.
Apparently it hasn’t been run for more than 20 years, the machine belonged to the grandfather of the late husband of the lady I bought it off, and has been in storage since, but it has compression and appears fully complete so hopefully its fixable!April 18, 2016 at 8:58 pm #20606
charlieKeymaster5900 May 1929- 6397 Oct 1930 498 machines, if information I am looking at is correct.
April 18, 2016 at 9:55 pm #20608
roatavatorParticipantThanks Charlie!
April 19, 2016 at 10:15 am #20615
will-haggleParticipantApril 19, 2016 at 8:43 pm #20624
roatavatorParticipantThanks Alan, I posted them on the road, Jr driving Commer at 40mph produces 95 decibels according to my Ipad, must have rattled the brain!
June 26, 2016 at 7:06 pm #21266
roatavatorParticipantWell, finally got round to looking at the A5, half a day cleaning and lubricating magneto, fuelled up and away she went! (small video size as rushed indoors to pinch Mrs R’s phone in case it stopped!)
Of course, after stopping it to put oil in gearbox and look at air cleaner, it now won’t go, but hopefully she’ll be reliably running in time for Little Ellingham working event in July!June 27, 2016 at 2:38 pm #21275
charlieKeymasterSounds as if it is four stroking at times engine note changes from the usual two stroke sound to a harsher crack and sounds as if it has slowed down. My 56 does this.
June 27, 2016 at 3:39 pm #21276
trusty220KeymasterIt’s normally a sign of an over-rich mixture. Is the main jet adjustable?
June 27, 2016 at 7:19 pm #21279andyfrost
ParticipantSounds just fine to me Peter , a correctly set “stroker” should fourstroke when not under load , give it some work and as Neil said in the song “what a beautiful noise”.
June 27, 2016 at 9:07 pm #21280
roatavatorParticipantYes, I wasn’t entirely sure about the running, she was 2 and 4 stroking but then the other SIMARS in my stable do as well. It doesn’t want to rev particularly high, but I’m not sure if this is because it was never meant to being quite a bit older than my 56. And of course she hasn’t run forover 20 years, so might have a bit of clearing out etc. She was a bit smoky, but that might be old oil in being burnt off ( I used the same mix as the 56 which doesn’t smoke much). I haven’t looked at the carb, if its like the other machines then there’s not an easy adjust for the mixture. If she goes again (!) I’ll see what she’s like under load at Little Ellingham before looking for trouble!
June 28, 2016 at 6:04 pm #21293
charlieKeymasterThe carb on the 56 has no adjustment for mixture, two fixed jets, probably worn.
July 2, 2016 at 4:30 pm #21323
roatavatorParticipantI decided the timing was wrong, adjusted and now running a lot better.
July 2, 2016 at 5:49 pm #21324
roatavatorParticipantHere’s the link, she will now rev very freely and feels as if she has power to work.
