Hello Joegrgraham.
I have used 5-10% of Kero in a Howard Gem with BJ engine a lot in the past, it made it run much smoother, and started better when hot, I think it burned enough oil to do without the 2 stroke oil!
I would try it, but only in an engine with relatively low compression ratio, or you will find it suffering from detonation.
Good luck
Chris
