Monro tiller villiers C12
Home › Forums › The Machinery Forums › Pedestrian operated machines › Monro tiller villiers C12
  • #39811
    mitzygolf
    Hi it’s me again. I solved the spark problem by fitting a new condenser but now nothing I do can get the engine firing. I have checked the timing several times and it looks spot on to me. I spray a little carb cleaner in to the pot turn her over and not a chance of firing. Any ideas
    #39812
    Valves / Compression?
    #39814
    enginear
    As Wristpin stated is compression good, if you take spark plug out and stick your thumb over hole turn engine over quickly and it should blow off and if you lay plug on head at same time as your thumb is blown off a spark should be seen, if not have you had engine apart and got valve timing wrong.
    #39815
    mitzygolf
    Checked the valves with a deeper and there is hardly any move many on the piston. I think I will check compression for peace of mind
    #39816
    mitzygolf
    That should read ” feeler “
    #39817
    mitzygolf
    And “movement”. Bloody predictive text!
    #39818
    mitzygolf
    I haven’t had the engine apart and it ran before the spark problem. It’s a mystery
    #39819
    mitzygolf
    Valves are both closed on tdc
