Monro tiller grease nipples
Home › Forums › The Machinery Forums › Pedestrian operated machines › Monro tiller grease nipples
  • #38174
    Hi, can anyone tell me what thread and size the grease nipples are on a 1954 monro tiller please. I can’t get the grease to pump through the originals as they have an end which doesn’t seem to clip into the grease gun. Thanks
    #38178
    Sounds as though you have the old “ straight” nipples as used on lots of older kit – vintage cars, Suffolk and Ransomes mowers to name several. You can possibly pick up a pump type gun with a suitable connector at an auto jumble . If lubrication is more important than originality just switch the nipples to modern “snap-on “ ones. ( Type, not the tool seller!). Threads could be BSP or UNF – a Monro tiller collector can probably advise you.
    A trick that was used by old school mechanics was to lay a piece of thin clean cotton cloth over the nipple and apply the gun connector over it providing a seal while still allowing grease to be forced through it.
    #38179
    Thanks. I’ve tried 1/4 bsf and 1/4 bsp. bsf was too small, bsp too big. I will try 1/8 bsp. Fingers crossed. Thanks for your reply
    #38180
    Which grease nipples are you referring to? The ones on the wheel hubs or miller drive.
    The wheel hub grease nipple MT632 on later machines is listed as a Tecazerk Type 6082.
    GR 10 for MT341 miller drive housing is only listed as grease nipple. I will have a look at one and see if I can work out size.
    #38182
    Hi Charlie, it’s the ones on the Miller drive. Thanks for looking
