Villiers engines interchangeability
Home › Forums › General › Help and information › Villiers engines interchangeability
  • #45048
    peterc
    Villiers engines interchangeability. Hi, does anyone know if parts for a Villiers C15 will fit a Villiers MK15? I’m thinking of the cylinder head or valves. The engines look quite similar. Thanks.
    #45049
    A quick look in the parts book and it would appear valves are the same, inlet EM 1169 exhaust EM 1071. Cylinder heads have different numbers by the look of it, although not clear.
    #45050
    peterc
    Hi Charlie,
    Thanks for your reply. That’s very useful. I’m actually looking for an exhaust valve for the MK15 and I’ve located an old C15 engine. It may be able to help me get the MK15 running again!
    #45058
    davidbliss
    Have been clearing out stuff and came across 1-5HP Petter head gasket, valves and bits with some Villiers. Head gaskets, 12, 25 and think 60? I often had one under overhaul as been some while since had anything to do with those its bit of a guess. If anyone needs them are free.
    peterc
    Hi David, thanks for the offer. I don’t really have a need for any of these parts at the moment. I hope you find someone that can put them to good use. Thanks.
