Hi Joey,
I have the same engine on my Trusty and had the same problem.
I’m afraid it is probably the coil that is kaput, but it would be worth getting it tested first, just to make sure.
You cannot get new coils for the briggs engine, but they can be re-wound. Private message me if you want contact details for magneto rebuilds.
To test the coil properly you will need to find someone with a suitable tester, your local garden machinery repair centre may be able to help. Testing with an multi meter will only be able to identify open or short circuit, it will not show if there is low insulation which breaks down when coil is in use.
I had trouble with a zz years ago and it seems the trouble was a slight oil leak from the crank seal which allowed oil onto the points. Might be worth checking. Good luck.
Author
VHGMC Forums
