Trusty self-lift cultivator.
Home › Forums › The Machinery Forums › Pedestrian operated machines › Trusty self-lift cultivator.
  • #9360
    joegrgraham
    The above is the currant project, very seized!
    This may be a silly question, but the inner drum of the lift mechanism (in pic) should this be fixed and everything moves around it, or should it be able to turn on the shaft, it has a grease nipple so I’m presuming the latter but I want to make sure.
    Joe,
    It’s been a long time since I used mine, but from memory the drum has to revolve around the shaft. The pawl inside it is operated by the lever at the back of the machine- in one position the wheel is free to rotate (when in work) and in the other position the pawl moves out to contact a stop which locks the drum to the wheel, in effect making the rotation of the wheel do the work of lifting the frame out of the ground. This is why only the left hand wheel has strakes cast across the tread so that it can grip enough to drive the lifting mechanism. The right hand wheel only has a ridge cast into the tread in line with the direction of travel.
    #9421
    joegrgraham
    Thanks Geoff,
    That was pretty much how I’d guessed it worked, just needed some confirmation before I got too brutal with!. It will be off to the forge next week to free off a couple of the more stubborn pieces!.
    Unfortunately, it is a bit rougher than I originally thought, I’ve had to cut pretty much every bolt, so I think this one will have to get a paint job. What is the correct shade of green? I’ve got a tin of Lister green which doesn’t look too far off others I’ve seen.
    Joe
    #9429
    There wasn’t an exact shade that the factory used; it was difficult to buy any paint at the time unless it was the same shade used by a major user (such as Army, Royal Navy, etc.).
    The shades of green that were used seemed to vary from Mid-Brunswick Green through to Dark Brunswick Green, and the wheels on the implement were painted in the same shade of green to match.
    Keep persevering with it- it means another one saved.
