thanks for the info of your experieces with this type of wheel combination. I suppose the different climates between G.B and AUS makes all the difference to how you go about your farming globaly. But I will add that using any machine in over wet conditions will ,like you say pick up soil/mud and also cause a ” PAN” effect in the soil structure once the tractor has passed along a given route.
