thanks john, well its day 3 of the build, took some 12″ wheels and hubs off one of those old red things and stuck them on the back, found an old diesel engine on the shelf and got it fitted, now you can see why i used the rear axle that i did (the drive is on the left) then i had to make the dashboard 3″ taller to fit over the engine the next job tommorow is to start making the other panels fit. Now the hardest part for me with this build is i want the finished tractor to have the oily rag look and i have never done that before
