Home › Forums › The Machinery Forums › Pedestrian operated machines › Ransomes 16’’ MK11
- This topic has 13 replies, 4 voices, and was last updated 6 years, 2 months ago by
May 22, 2020 at 5:27 am #34436
vhgmcbuddyKeymasterHi everyone,
My name is Louis, I live in Belgium (Namur). I am trying to revive a Ransomes 16’’ MK11 with a Ransomes 4 stroke engine, but some pieces are missing – piston segments, exhaust pipe, and a small screw on the side of the carburettor, and I don’t find any spares parts in Belgium. Would any of you have an idea of where I could find these parts? Many thanks to all and regards -LouisMay 22, 2020 at 9:23 am #34437expeatfarmer
ParticipantLouis
I am currently breaking a 36″ mower fitted with the Sturmey Archer engine there may be some common parts can you post photographs of your machine.May 22, 2020 at 6:49 pm #34440
vhgmcbuddyKeymasterHello expeatfarmer, thank you for your prompt reply. I forgot to take pictures of the machine before removing the engine, but I could find pictures of a complete one on the internet (you see the exhaust pipe I am searching for). With regards the carburettor you see on my picture the small screw missing. Many thanks for your help.
May 23, 2020 at 8:36 am #34446
charlieKeymasterIf you are unable to find piston rings it is possible to have them made. A UK company that can make them is Cox and Turner Engineering
The missing screw on the carburettor looks like it is the tickler for flooding the carb. It may be worth contacting a carb company such as Burlen FuelsMay 23, 2020 at 9:27 am #34447expeatfarmer
ParticipantThe engine is I believe a Sturmey Archer, the “screw” missing from the carb is as Charlie says a tickler plunger to flood the carb, the silencer I have is very similar I will take a picture.
May 23, 2020 at 5:38 pm #34452
vhgmcbuddyKeymasterYes, you both are right, it’s the tickler plunger. Thank you for both adresses, I’ll surf on their sites.
Behind the mag chain (« Ransomes »), one can read « LSA 125 », I suppose for Sturmey Archer.May 23, 2020 at 10:57 pm #34460
vhgmcbuddyKeymasterHi There look at the side of the mower,the opposite side to the chain case.You’ll find a cast disc,tell me what it says and I will date it for you.
Kind regards
Andrew
Archivist
The Hall & Duck TrustMay 24, 2020 at 7:32 pm #34468
vhgmcbuddyKeymasterJune 3, 2020 at 8:29 pm #34580
vhgmcbuddyKeymasterHi all, I am very happy: I could find three segments, a spark plug and some material to weld an exhaust pipe. I will run in the valves next weekend, and look for the belt of the ventilator. My brother, whose venerable BSA motorbike sometimes needs to be repaired, told me I might find a tickler on Faked.com; let’s wait and see… The mower is nearly operational, after having slept half a century in an old orangery…
See youJuly 23, 2020 at 6:46 am #35069
vhgmcbuddyKeymasterJuly 23, 2020 at 7:35 am #35071
charlieKeymasterGreat result.
July 29, 2020 at 4:30 pm #35130
vhgmcbuddyKeymasterthank you. But would someone tell me how to stop the engine? Up to now I close the fuel tap and wait for the carb to be empty, but there must be a more convenient way, am I wrong?
July 30, 2020 at 8:20 am #35136
charlieKeymasterThere should be a metal tab on the side of the magneto at the points end near the clips that hold the points cover on. Press to stop.
July 30, 2020 at 7:10 pm #35137
vhgmcbuddyKeymaster -
