To remove gudgeon pin (wristpin) remove the clips part number 10297, see parts manual plate 2 for illustration.
If it’s an alloy piston, with clips removed, suspend it in a pan of boiling water for five minutes and it will probably expand enough to allow the pin to be just pushed out. Failing that make a tool similar to this to push it out. No apologies for its rather crude appearance as I made it in about 1960 when playing with Lambretta scooters. Amazing how many pins it’s pushed out on a variety of engines since then.
