Home › Forums › The Machinery Forums › Pedestrian operated machines › Monro tiller tine shaft bearing – she is broke!
- This topic has 14 replies, 2 voices, and was last updated 10 years, 1 month ago by
May 1, 2015 at 6:34 am #12813
vhgmcbuddyMemberHi everyone – I’m a lapsed vhgmc member, owner of a series3 Monro Tiller. I’ve had a year or two away playing with vintage mopeds, but am better now and back to rotavators (sounds like my application to AA!).
Anywho, wonder if someone can help? Using my Monro Tiller last week and have dislocated the tine shaft from the nearside bearing cup. Looks like the bearing is simply a plain bush, but I’ve lost the felt seal and cap, I guess these was perhaps a thrust washer on the end of the shaft.
Anyone any recent experience of refurbishing these bearings?
Any ideas welcome, and thanks for letting me back in.
James BirdMay 2, 2015 at 7:06 am #12827
charlieKeymasterJames welcome back. Do you have an owners manual? This has an illustrated parts list which will help identify what is missing. Best option would be to strip it down and see what is worn or missing.
May 2, 2015 at 4:57 pm #12835
vhgmcbuddyMemberHi Charlie, nice to hear from you. Looking at the manual you supplied, I’ve lost MT39 – Miller axel felt washer small, and my MT40 bearing cap end, I’d have thought my RC40 spring washer has gone and I may have lost the compo bearing MT361, it wasn’t on the end of the axel, but may be caught in the shell.
I guess the simplest way forward is to drill out the rivets and remove the shell from the outside? And then see what’s what. I can bolt it back in with suitably sized bolts an nylocs?
$64,000 question is will I be able to source something to replace the bearing, or will I be able to find a bearing assembly in an gash miller attachment.
I’m guessing that built in ’63 it’s now out of warrantee – poor show that like rolls Royce they’ve not sent their man round yet to fix it for me!May 4, 2015 at 12:26 pm #12885
charlieKeymasterI will have a look at my series 3 and see what is what and hopefully come up with a solution to your bearing problem.
May 6, 2015 at 6:38 am #12941
vhgmcbuddyMemberThank you Charlie, we very glad of any advice.
JMarch 4, 2016 at 4:01 pm #20123
vhgmcbuddyMemberHi everyone, it’s that time of year – sap is rising and I need to get allotment dug – But strangely my Series3 Monro Tiller has not mended its self over winter!
I’m after a replacement miller shaft bearing – Does anyone have a miller unit they’d be prepared to drill the bearing shell out of? Money, or beer or beer money available as appropriate. The part I’m after is the nearside bearing assembly that supports and locates the non driven end of the main miller tine shaft.
Be very glad of any help.
Thanks
JamesMarch 5, 2016 at 8:10 am #20128
charlieKeymasterJames, I must see what I can find.
March 5, 2016 at 3:28 pm #20145
charlieKeymasterMarch 5, 2016 at 6:54 pm #20152
charlieKeymasterJames, having a look through the parts list, the miller shaft spigot housing MT38 (as shown my photos above) houses the bearing MT361, and is held in place by four 1/4″ x 1″ Whit coutnersunk screws MT362, spring washer RC40 and nuts RC212.
Can you post a photo of your miller shaft and damaged bearing etc?March 5, 2016 at 8:37 pm #20153
vhgmcbuddyMemberCharlie, thank you. Will try get to allotment Sun and photograph. My memory is my shell is riveted in and don’t think it’s got a greese nipple. But may be remembering wrong, and anywho I’d be sure they could be interchanged. Thanks for the pics, I’ll be back to you soon as I can.
Best
JamesMarch 7, 2016 at 7:35 pm #20160
vhgmcbuddyMemberHi Charlie. Poor quality photos attached. The damage was caused by (I guess) a big stone getting dragged around, distorting the side of the casing and dislocating the shaft out of the bearing, breaking the tin cap and tearing the large felt washer. I’ve cleaned up the bearing and popped the start back in. But, having now looked at the manual you supplied a while ago I worry that the spring washer is gone as perhaps the is the ‘compo’ bearing (compressions? composite construction?). There’s no doubt my bearing cap is riveted in – look like v large pop rivits and that I don’t have a greese nipple (nor the hole where a snapped of one went).
The upshot is I guess I could use what I’ve got, but I’m worried I’ll just damage the end of the shaft with the remains of the bearing. If I could I’d like to get a replacement assembly that hopefully is more complete.
Is the one you photoed available at the right price?
Thanks for you help
JamesMarch 7, 2016 at 8:24 pm #20161
vhgmcbuddyMemberMarch 8, 2016 at 2:59 pm #20164
charlieKeymasterJames, are you sure it is riveted? It should have countersunk screws with nuts on inside, mine has had normal nuts and bolts fitted and appear to be slightly different design as no counter sunk hole. If the shaft is still a reasonable fit in the bearing you should be OK so long as bearing is well lubricated. Long term it will need a felt washer and cap.
March 9, 2016 at 8:34 am #20171
vhgmcbuddyMemberI was thinking I could fabricate a cap out of some tin plate, the felt washer obviously easy enough. My remaining worry is the spring washer, which I guess is in effect a thrust washer? I’ll disassemble one more time this weekend and check. I’ll also check rivits vs bolts. Could it be the late series 3 had reduced themselves to rivits rather than bolts? My machine numbered 234575, and I now can’t remember how I’ve mixed and matched the parts various as I’ve acquired finger mower, hoe, plough etc.
Back to you this weekend.
ThanksMarch 9, 2016 at 3:04 pm #20196
charlieKeymasterSpring washer RC40 is for the fixing bolts, not a thrust washer. Below is an extract from an earlier parts list for the series 3 which shows the parts laid out in the correct order.
