Home › Forums › The Machinery Forums › Pedestrian operated machines › Monro tiller gearbox oil capacity
- This topic has 12 replies, 3 voices, and was last updated 3 years, 8 months ago by
June 24, 2022 at 1:03 pm #39257
mitzygolf
ParticipantJune 24, 2022 at 8:06 pm #39265
charlieKeymasterGoing from memory I don’t think the capacity is given.Fill the main gearbox till level is reached on long dipstick. Use a non EP oil such as Morris Oils AG140. Owners manual gives details of checking oil is getting to worm gear assuming it is a machine with oil pump.
June 24, 2022 at 10:16 pm #39267mitzygolf
ParticipantThanks Charlie. I know you’re an expert, is the transfer the right way up. I didn’t think so the as soon as I applied it
June 25, 2022 at 6:54 am #39268
charlieKeymasterUnfortunately you are right, the transfer is the wrong way round.
June 25, 2022 at 10:12 am #39270mitzygolf
ParticipantIf I put another one on top would it stick?
June 25, 2022 at 5:04 pm #39288
charlieKeymasterIf I put another one on top would it stick? I don’t know as I have never tried.
June 27, 2022 at 2:13 pm #39333mitzygolf
ParticipantJust tried to start it. No fuel mixture getting to the cylinder. Float chamber is filling up and when a little fuel is added straight in to the cylinder it runs. I put a replacement main jet in during the rebuild ,does the taper needle and jet need to be paired? Any ideas would be very helpful. Thanks
June 28, 2022 at 7:23 am #39354
charlieKeymasterJune 29, 2022 at 7:26 pm #39381mitzygolf
ParticipantJune 29, 2022 at 7:30 pm #39385mitzygolf
ParticipantJune 30, 2022 at 7:21 am #39387
charlieKeymasterYes you can order another transfer, drop me an email, contact details.
June 30, 2022 at 2:19 pm #39388
wristpinParticipantVery smart, but I have to ask, are the tyre treads supposed to be facing in different directions left and right?
July 1, 2022 at 8:11 am #39395
charlieKeymasterThe wheels can be reversed to give a different off set. If one is at narrow setting and the other is at wide setting then it would have one tread facing the opposite way. If both wheels are on the same setting then yes it would appear one tyre is on the wrong way round.
