MG FUEL FILTER
Home › Forums › General › Help and information › MG FUEL FILTER
  • #34787
    chris
    Hello everyone
    I have a diesel mg 6 possibly a 40, ( place says 6 decals says 40) it has a vokes ltd fuel filter , but I can’t find a cross reference for it.
    I planned to fit a AC 60 filter assembly instead off an old engine but the centre bolt only enters about one turn and is clearly not long enough.
    Does anybody know what size and thread the centre bolt should be on the AC 6o or AC 600 filter assembly or know where I could get the vokes element
    Thanks Chris
    #34792
    chris
    Well after an afternoon of rummaging through various boxes and cans of bolts I have found one a bit longer in 1/4 UNC, I have run a tap down the filter housing again 1/4 UNC (1/4 and 6 mm use taps always difficult to find, they break easily) and with a fibre washer all assembled and fitted!
    Next question is, I intend to fill and run the tractor on white road diesel , for the amount I will use it’s not worth the effort to get red diesel.
    Is there a down side to white as it is a higher cetane number?
