Howard Yeoman chain pitch?
Home › Forums › The Machinery Forums › Pedestrian operated machines › Howard Yeoman chain pitch?
  • #28377
    Can anybody please tell what the chain size/pitch is for the Yeoman rotors. Mine has just broken and I need to buy a joining link of the right size. The parts list does not quote this detail. Thanks
    #28390
    Hi
    sorry just assembled the rotor box on mine. The pitch of the join would be the same as the pitch of the links, if you have a Vernier this should give the measurement. The Yeoman is definitely an imperial size.
    Jeremy
    #28397
    Thanks for you reply Jeremy. I have brought a 630 split link (yet to be delivered) based on the measurements I made with a digital calliper. However only 2 of the three measurement seemed to tie up exactly to what’s available, thus my enquiry. I have had motorbikes for 30+ years (most chain drive) so I am used to the various pitch measurement. I hope what I brought fits. Most chain measurement are imperial even nowadays.
    #28433
    I hope that the link worked in the end. Finally started using my machine after a full restore over the winter and many problems with the clutch. Best of luck Jeremy
