howard gem stub axle bearing
Home › Forums › The Machinery Forums › Pedestrian operated machines › howard gem stub axle bearing
Viewing 1 post (of 1 total)
  • #34295
    I have removed the stub axle assembly from the rotor tube, does anyone know the correct bearing reference? although mine hea made in england, the identity has been worn away, I can see that it measures 1 13/16″ wide, but I cant check the bore without removing the axle pin , and I dont want to wreck it if I cant get a new bearing, has anyone taken the bearing off without a workshop press? as in the manual. Regards Plonker
