howard 350
  • #14841
    how can i seal a fuel tank that has had rust in. have cleaned it with vinegar and 1. cups of salt for a week thanks
    #14842
    Have a look at Frost Restoration website other tank sealing kits are available.
    #14845
    I’ve read of mixed results with sealant, particularly since the introduction of ethanol adulterated fuels. I have successfully cleaned very rusted tanks by electrolysis using an ordinary battery charger as a power source.
    Once all the loose rust has been removed either keep the tank full to exclude air or completely empty with a moisture absorbing pouch in it.
    You can buy a kit off that well known auction site to do this. The product is from America (where they’ve had this crappy petrol for some time) and it’s called SLOSH. I used it on the Norton engine rebuild in the Project section and it comes with a bottle of cleaning agent that you swill around before putting in the sealant.
    It goes off to a hard finish like Araldite and seems to be OK so far, just make sure that you roll a piece of card into a tube and put it in the outlet hole so that the threads don’t get too gunjed up with it. If they do just run a tap through to clean it out.
    Expect to pay about £30 for a kit. I hope that helps.
    #14855
    I think that the cleaning agent is important as it aids the bond between the sealant and the tank. Over the years there has been a lot of chat on the Lambretta forum reporting that some of the product on offer has collapsed inside the tank like a deflated balloon!
    Hopefully the current products are better. Personal experience with any product from Frost is that, if used correctly, it usually does what it says it will.
