Home › Forums › The Machinery Forums › Ride-on machines › Hayter 10/30 wont drive
- This topic has 28 replies, 5 voices, and was last updated 6 years, 3 months ago by
May 23, 2020 at 2:39 pm #34449
vhgmcbuddyKeymasterI have the fabulous Hayter 10/30 which i have used for over 10 years (I bought it second hand and restored it the best I can). It picks up grass, mulches and throws it out if required.
It has worked fine for all those years bar the odd belt replacement.This week after cutting, it suddenly would not drive after i switched it back on after
stopping briefly.
Not forward or reverse. Additionally the brake does not work ?
The engine runs fine.The drive belt has not broken either. (I have not yet replaced it as usually when
a non drive issue happens it is the belt snapped)In any gear engaged I can push the mower forward and back with no restraint.
With the brake on i can push the mower forward and back the same.This was sudden ?
I have adjusted the clutch mechanism to no avail.Any ideas ?
(Just so you know I am very familiar with mechanics and have restored
4 vintage motorcycles but this has got me ?)
Help …….May 24, 2020 at 6:01 pm #34467
wristpinParticipantFor a start, does it have a hydrostatic or gear drive transmission?
When the machine is stationary with the transmission in neutral but with the drive to the transmission engaged, can you see the transmission input pulley going round?
With the rear of the machine raise with both wheels clear of the ground, does turning one wheel cause the other one to rotate. Give an outward tug on each wheel – are they firmly located.May 25, 2020 at 7:04 am #34470
vhgmcbuddyKeymasterGear drive, manual select !!!
Update on drive tests:
– is the pulley on the trans-axle going round with it in a gear and engine running – drive mode = YES
– With rear wheels off the ground and in gear do the wheels engage the gearbox when turned ? = NO
Tests to do today:
-When the machine is stationary with the transmission in neutral but with the drive to the transmission engaged, can you see the transmission input pulley going round?
-With the rear of the machine raise with both wheels clear of the ground, does turning one wheel cause the other one to rotate. Give an outward tug on each wheel – are they firmly located.One thing – as per pic the drive pulley seems to be loose ? (stock pic)
i.e can spin freely in gear or not and is loose ?
Is this right ? perhaps the bolt on the top is loose ? (This will
need me to remove transaxle to get to it)May 25, 2020 at 9:09 am #34474
vhgmcbuddyKeymasterUpdate on tests:
No wheels do not rotate when one is turned.
They are located firmly.Update on drive pulley.
It is only loose when drive pedal on (brake on)
When brake off (in drive mode)it is tight and belt tight which
must be as it should be.May 25, 2020 at 2:48 pm #34478
wristpinParticipantIs there a manufacturer’s tag on the transaxle . Looks like it may be a Spicer ?
May 25, 2020 at 2:57 pm #34479
alanParticipantJust for info, there are handbooks and parts lists to download on the Hayter website;
May 25, 2020 at 4:36 pm #34480
vhgmcbuddyKeymasterThanks yes i have the manual … heriatge hayter code 130s
Transaxle:
Yes it is a spicer.
pic attached(It looks simple to get off the transaxle….. the issue i fear is what
on earth is wrong with it and how would one know looking at all the cogs that will be there.?Do you guys think it is as a item within the transaxle ?
I could find another and then look at mine at leisure (with your help ……..)
(The mower is more to me than a mower you see but now a family friend)May 25, 2020 at 6:25 pm #34484
wristpinParticipantThe simple failure is that the input pulley has stripped its splines and is turning without turning anything within the trans axle. It still means splitting the ‘box to replace it – I think . Although I have seen them welded as a quick get out of trouble.
Unfortunately I left all my transmission data and parts books behind when I sold my business in 2012. The business was subsequently closed and all that sort of thing got binned.May 25, 2020 at 6:58 pm #34485
vhgmcbuddyKeymasterWhen you say input pulley is that what I see as the drive pulley ?
as per in pic.splines in the pulley or the rod it sits on (clearly needing transaxle splitting) ?
I can have the transaxle out tomorrow (I am expert at managing old stuck bolts …)
Unfortunately the manual does not delve into the transaxle so
as you inform parts may be an issue.I am considering buying a second hand one and fitting and sorting
this out at leisure..
Not being a mower engineer it may be wise for me to buy another
second hand working transaxle ?May 25, 2020 at 10:57 pm #34488
wristpinParticipantYes the pulley that inputs the drive to the box. If the shaft does have stripped splines, just check that it can’t be changed without splitting the box. On many of the Tuff Torq boxes that we used to distribute that shaft could be changed with no other dismantling.
May 26, 2020 at 7:13 am #34489
vhgmcbuddyKeymasterMany thanks …… what a site this is .
I cant tell you how thankful I am.I will remove the transaxle today and investigate.
I will update the post.May 26, 2020 at 10:44 am #34491
vhgmcbuddyKeymasterUpdate.
Transaxle out as per pics. (pics reduced for site convenience)
Jacked up on tow bar, wheels off , brake and clutch disconnected from rear pins,
drive belt hooked over pulley, 4 bolts holding transaxle – now off– if i put TA (Transaxle) in gear on bench and turn axles A and B they turn the other
side respectively. BUT not the drive pulley. that remains stationary.– the drive pulley is made to pull off after removing a (circle hlding washer – cant think of the word) so the pulley itself is ok.
– When in gear , drive pulley on, and i turn the drive puller i can see for the smallest amount
of time the axles move for a millimeter but then stop and the pulley moves freeley.So that is the analysis …… it must now be internal.
I will gunk down the TA and spray the bolts with pen’ oil and will consider
going deeper.But I think i can find another for 100£ which may save me for now.
May 26, 2020 at 12:29 pm #34496
vhgmcbuddyKeymasterUpdate:
I have bought another transaxle (100£) , the same for sure,
so can sort this transaxle at leisure.So this thread continues in two branches.
I’ll split the transaxle I have and see
what the input rod thing is doing.
Does that sound like a plan ?
(Without your help I’m finished !!!!!)May 27, 2020 at 2:43 pm #34505
vhgmcbuddyKeymasterOld transaxle external drive pulley components:
As per pics but a washer and a key to stop pulley rotating freely are worn.
Not useless but worn to almost non functionality.
(Not the reason for this drive problem)found a online parts diag for a transaxle – Spicer dana 4450 3
pic shows input shaftMay 28, 2020 at 7:38 am #34512
charlieKeymasterWith gearbox in gear and input shaft locked to prevent it turning, if you turn one half shaft does the other one turn in the opposite direction? This will confirm halfshafts and diff are in good order, no major failure.
If you turn both together in the same direction with gearbox in gear does the input shaft turn or try to turn? -
