Hako tractor with JLO 2 stoke diesel engine
Home › Forums › General › Help and information › Hako tractor with JLO 2 stoke diesel engine
  • #37888
    trojan
    Hi,
    Don’t suppose anyone has any information on a Hako tractor (Chassis number 90-00149-6 H) fitted with a JLO 2 stroke diesel engine, I can but ask?
    Looking for anything that will help me with dating the tractor, any instruction books for the tractor itself or the engine – even in German.
    The one that I have is complete (I think) was up and running but needs a lot of TLC before it will ever grace a rally field again
    BR
    P
    #37895
    Any photographs of tractor and engine, may help with sourcing information.
    #37928
    trojan
    Hi, unfortunately my tracor is currently in bits being restored but here is a photo from the internet of the model I have if it helps
    best regards
    Trojan
    trojan
    here is a (bad, apologies in advance) photo of the JLO engine, the engine itself is interesting The engine is a single cylinder 2 stroke, air cooled diesel, Type DL425 8,00hp at 3000 rpm, Engine number 2051019? The number cast into the alloy cylinder head is 425 07 101 – 10 A, it has an electric start, with a glow plug to aid starting. It has an interesting lubrication system, the oil is held in a separate tank next to the diesel fuel tank then pumped to the crank shaft bearings before running into the crankcase where it is scavenged by the incoming air and burned with the injected diesel fuel.
    BR
    P
    trojan
    Hi Skookum,
    many thanks indeed for this information, I’ve not translated it all yet but it’s certainly going to be helpful
    again, thanks
    Peter
