Home › Forums › General › Help and information › Engine block rebore
- This topic has 4 replies, 4 voices, and was last updated 1 year, 4 months ago by
tractorman.
September 30, 2024 at 9:41 am #43015
tractorman
ParticipantHi l have a Briggs side valve aluminium block engine on a Howard 300 rotavator
The block is scored , l do have a genuine Briggs replacement oversize piston and rings
Does anyone know of anybody who rebores aluminium block such as this
I would like to keep Howard original rather than fit another engine and crank size is smaller on many newer engines
Regards DavidSeptember 30, 2024 at 12:43 pm #43017
charlieKeymasterI would suggest you search google for engineering companies in your area that do engine machining such as rebore.
October 1, 2024 at 12:45 pm #43019
sidevalve5ParticipantHad a similar problem with a Kohler K181 engine after inspection when I took it apart. Got a rebuild kit from the USA with an oversize piston and struggled to find an engine reconditioner that would do the rebore. They had the machines set up for large engine blocks and one said just breaking it down and setting it up for a small block would take the best part of an hour. But did eventually find a chap at Kidderminster who does them. You may have to make many phone calls, but will find someone somewhere. A tip maybe is look to see if they do British motorcycles, there are several in the West Midlands. The Kohler rebuild kit only cost about £70 and was a bit sceptical if the parts were of reasonable quality. Should not have feared, they were fine, with ideal limits and fits tolerances. Have a mate with a Honda GX160 on a Merry Tiller that smokes like a steam engine and runs terrible. Am going to take that apart this winter and if the bore is within service limits, will get an after market rebuild kit for that too. Can you believe they are less than £20.
October 10, 2024 at 8:04 am #43034davidbliss
ParticipantIf you have a problem see if you can find and ask a vintage motorcycle enthusiasts lads as motor cycles have much smaller bores than most Briggs engines, going back to when they started to use all alloy non sleeved engines was told they couldn’t be bored, but an old engineering friend used to do them without fuss and seem to remember them saying after boring used a different hone.
October 10, 2024 at 9:16 am #43035tractorman
ParticipantThanks guys l have been exploring this project for a while and you are right most engineers don’t want to be bothered with a small single cylinder in aluminium!
But the motorbike repairer is an avenue worth exploring l hadn’t thought of that ,
Many thanks David -
