Carburetor on a Villiers MK 15 HS
Home Forums The Machinery Forums Pedestrian operated machines Carburetor on a Villiers MK 15 HS
  • #38592
    bmterrier
    I am working on a Howard Bantam with a Villiers MK 15 HS engine. Does anyone know what type of carburetor it has? It is shown on the attached photo. I am looking for spare parts for the carburetor.
    Best Regards
    Bo
    davet
    Hi, If you look at Scribd.com/doc/117878257/Villiers Mk15 pdf page 21. Looks like your carb, good breakdown drawing and parts list.
    Regards. Dave T.
    #38597
    I would have said try Meetens, however they have now closed down and L&S Engineering have taken on the business, it might be worth giving them a try.
    Alternative could be Villiers Parts
    #38617
    The carb you need is an S12, as used on small motorcycles from James & Francis Barnett before they started using the dreaded AMC engines! Villiersparts.co.uk do a refurbished one, or https://www.themowercentrehailsham.com/
    #38618
    Here’s a spec. sheet for the James Comet L1. 98cc. 1956-1964 which used the S12 carb.
    https://simplywizard.co.uk/folders/specsht/l1ss.htm
