Ok, latest news…
I have managed to release the pulley. I made a wooden cradle and using a drift tapped out the steel shaft. Easy with a little thought!
I can now see the offending article – BS20 1 5/8″ bush is quite worn. It looks like it should be captive in the case which would hold the input shaft in place (DA1496Q). The fact is that it is so worn that it just slides in and out.
Any suggestions – replace, roe manufacture, is there a repair?
C
