Home › Forums › The Machinery Forums › Pedestrian operated machines › colwood power barrow
- This topic has 11 replies, 5 voices, and was last updated 10 years, 4 months ago by
August 15, 2015 at 7:23 pm #14063
vhgmcbuddyMembernew to forum , just got a colwood power barrow , looking to restore and show
not running at moment
cheers peteAugust 16, 2015 at 3:16 pm #14072
vhgmcbuddyMemberWelcome to the forum Pete
Any photos of your machine please ??
August 17, 2015 at 7:43 am #14084stevewoollas
ParticipantI have some pictures of this machine which I will upload tonight
August 17, 2015 at 5:18 pm #14091
steve-dParticipantHi Pete I would be very interested to see your colwood so I can add to the register, I also own a barrow attachment which I intend to restore over the winter, I also own 15 colwood machines in various states of repair.
Best steve.August 17, 2015 at 7:39 pm #14096stevewoollas
ParticipantHello Pete,
It was me who spoke with you just after you bought the Colwood Powerbarrow on Saturday and i’m glad you found the VHGMC website and Forum. Hope fully it will prove useful to you.
My grandson, Drewboy, took three pictures of the Colwood so hopefully you don’t mind me adding them on here.
Good luck with your restoration–SteveAugust 17, 2015 at 8:54 pm #14102
vhgmcbuddyMemberhi steve , thanks for adding photos
been playing with the engine today , got it running aftor a little bit of work
need to have a look at gearbox as lever is stuck and will not change
could anyone tell me how the pull start work on gear box ?
as mine does not seam to be catching anything inside ?
cheers peteAugust 18, 2015 at 7:48 am #14103
charlieKeymasterWhich model of Albion gearbox does it have? I may have a parts list or manual.
August 18, 2015 at 8:01 pm #14105
steve-dParticipantHi Pete this is all that remains of my barrow, and yours makes it only the third one I know of in existence, and I’m very impressed that your s looks original, and if possible please could I have any dimensions, it’s attached to a colwood model B series 2 with a Villiers mk 10 engine. It is not the easiest to explain gearbox, but it’s a two speed and when in neutral the clutch engaged allows you to start it on the handle.
August 19, 2015 at 8:46 am #14106
charlieKeymasterThe gearbox is like a motorcycle gearbox and the handle is in effect the kick start.
August 19, 2015 at 12:08 pm #14115
vhgmcbuddyMemberthink gearbox is no good as lever will go round in a circle now ?????
think something must have snapped inside ?
anyone came across this befor ?
any help would be really handy
cheers peteAugust 20, 2015 at 6:58 am #14129
charlieKeymasterAs I said before which model of gearbox is it as I may have a manual. I think it should have the type on the casing somewhere.
August 20, 2015 at 6:34 pm #14140
vhgmcbuddyMemberhi , will have a look and let you know
cheers pete -
