Wanted Simar Rototiller 56 Throttle Cable
Home › Forums › General › Help and information › Wanted Simar Rototiller 56 Throttle Cable
  • #7034
    Looking for a throttle cable for a simar rototiller 56 and need help finding one.
    message me with anything if possible
    #7064
    hortiman
    Hello craigfal123
    I suggest you try Jon Cruse, at The Mower Centre, Vicarage Road, Hailsham, East Sussex.
    He has a website I think it is googled at ‘the mower cemtre’ He makes up cables from patterns in stock or by copying your own old cable.
    well worth a try.
    Chris
    #7079
    01323 842477 is Johns Cruses Number
    #7088
    If you need the dimensions and details of end fittings I can give you them using the cable on my 56A.
    #7091
    Yeah that will be a great help thanks Charlie
    #7319
    Eventually got around to measuring the cable on my 56A.
    Overall length of outer cable 2.11m (83″) 6.12mm od, overall length of inner cable is 2.193m (86 3/8″) 1.5mm diam.
    Throttle lever end has a nipple 6.12mm dia 3.28mm thick and carb end has a nipple 5mm long 3.26mm dia (these are as close as I could measure). The adjuster on carb end is 32mm overall with 18mm threaded section. Cable with adjuster for carb end can be threaded through handlebars from throttle lever end, easier if a length of wire is threaded through first.
    Hope this helps.
