Home › Forums › The Machinery Forums › Pedestrian operated machines › Trusty Tractor
- This topic has 6 replies, 3 voices, and was last updated 10 years, 4 months ago by
trusty220.
September 17, 2015 at 12:56 pm #14447
vhgmcbuddyMemberHi Guys
New here and was wondering if any one could help with some information on how to start and use this monster.
It has the crank handle and I am getting a spark to the plug. I’m told there is no choke nin the carb so may need a replacement carb.
The tractor number is TC1010/4/44
Thanks
SteveSeptember 17, 2015 at 1:06 pm #14449
trusty220KeymasterWhat you have is a Trusty Earthquake which would normally have had a Villiers 20 or 25 fitted originally. The engine that you have fitted is a much larger one and I’ve come across one other like it- it was called a Villiers 4/44, which is also mirrored in the serial number. It appears to originate from 1965 if you compare it to the others in the “Survivors” listing.
Not all carburettors had a choke for starting, some had a “tickler” on top of the float chamber so that you could hold the float down and flood the carb with fuel. If you could show some photo’s of the front of the engine we may be able to give you an idea how to start it.
Best of luck with it!
September 17, 2015 at 5:16 pm #14451andyfrost
ParticipantYour engine is a form of Villiers/JAP hybrid , and should have a BV1320 Carb fitted , it most definately has a choke fitted(or at least should have) , have a look at the bottom of the Carb where the air filter pipe would join on , you should see the choke strangler there , the actuator was plastic and prone to breakage.
This Carb does not have a tickler.Get back to us if you’re still unsure.
October 21, 2015 at 12:39 pm #14891
vhgmcbuddyMemberHere are a couple of pics of the carb, I have checked the jets are clear on the carb but it looks like something is missing from the front of it.
So my question is can the missing bits be obtained or would it be easier to replace the carb?
October 21, 2015 at 12:51 pm #14892
vhgmcbuddyMemberOctober 21, 2015 at 4:10 pm #14895andyfrost
ParticipantYes , your choke assembly is missing , try calling Paul Childs at Meetens.
October 21, 2015 at 5:08 pm #14896
trusty220KeymasterHere are two pictures in my file that you may find useful. The Earthquakes don’t belong to me but were sent to me some years ago to help identify them.
Hopefully you can see what is missing. Don’t forget, though, the Earthquake never had a throttle lever and relied on the engine running at a constant speed controlled by the governor. -
