Hi folks…. a couple of weeks ago I got my rebuilt JAP back (and I heard it running too)…. have now got it bolted back on the front of the Howard and the darn thing won’t start. I’ve got a nice big spark (the best I’ve ever seen that mag produce), if I really wind it up I get an occasional polite cough that goes with the spin. The timing of the spark seems correct, the impulse is triggering just after TDC. There’s fairly fresh fule in it (that my Honda engines seem to run on happily enough).
All I’ve done to it since it got home is put an air filter on it and sorted out a throttle cable .
I’ve tried EZ-start, I’ve tried putting a bit of fuel down the plug hole and I’ve even tried putting EZ-start down there too…. nothing has worked so far…. occasional polite cough forwards… I’ve tried it with the plug that went on during the rebuild (a slightly odd looking long-reach thing as well as with a new old-stock Champion L10 (which was specced for the engine). THe Mag had a new condensor fitted as part of the rebuild and, two weeks ago or so, started ridiculously easily once I’d sorted the timing out to have the impulse kick in after TDC…
I did have to take the carb off to refit the aircleaner (the bracket is clamped by the two pieces of the inlet manifold), is there something drastic I can do to a Zenith 24T2 just by taking it off and on again?…. but then surely the @fuel down the plug hole@ trick would have worked…..any advice welcome
chrisc
