Home › Forums › The Main Forum Area › General talk and discussion › saved from the scrap man
- This topic has 21 replies, 8 voices, and was last updated 12 years, 2 months ago by
December 2, 2013 at 8:15 pm #3622
vhgmcbuddyMembersaved this to night alandmaster and a cast sign has anybody got info on this machine this will be my xmas project
December 2, 2013 at 8:19 pm #3623
wristpinParticipantWhat are we supposed to be looking at?!
December 2, 2013 at 8:32 pm #3624
vhgmcbuddyMemberwill try pics again
December 2, 2013 at 8:59 pm #3626
vhgmcbuddyMemberdont no wots gone wrong but its a landmaster rotary hoe mk1 will try pics again later
December 3, 2013 at 2:56 pm #3642
charlieKeymasterThe photo files are too big. You need to reduce the file size. Using software such as shrinkpic makes it easy.
December 3, 2013 at 4:43 pm #3644
wristpinParticipantShrinkpic possibly makes it easier but the facility is there in Windows – just right click on your image wherever you store it. Then click on “edit” and you get the option to reduce to a percentage of the original or to a certain number of pixels.
For general posts of images to forums I usually go to 20 or 25% of the original. If you are likely to want an unreduced image in the future I suggest making a copy a copy of the original and doing your reduction on the copy as once you have reduced an image there is a loss of definition if you enlarge it.December 3, 2013 at 4:55 pm #3645
charlieKeymasterThe great advantage of running shrinkpic is all you need to do is select the image and the rest is automatic, no messing about with opening another programme.
December 4, 2013 at 6:52 pm #3704
vhgmcbuddyMemberDecember 4, 2013 at 7:03 pm #3706
vhgmcbuddyMemberDecember 4, 2013 at 7:28 pm #3713sprayerman
ParticipantLooks like its going to be a good thing there won’t be too much TV to watch over the forthcoming season, just hope it doesn’t get too cold to work wherever you will be working.
December 4, 2013 at 7:52 pm #3714
vhgmcbuddyMemberwow the challenge is on ! theres nothing better than starting like that and getting the bit between your teeth and making it look as new. cannot wait to see it progress good luck catfish.
December 4, 2013 at 8:43 pm #3716
vhgmcbuddyMemberquestion is it a gamecock is that the remains ov a villers mk 10 engine wot colour was it originally any info appreciated hope full to make a start this side ov xmas gear box is jammed also catfish [aka garfield]
December 4, 2013 at 9:00 pm #3717
vhgmcbuddyMemberDecember 5, 2013 at 12:44 am #3723
wristpinParticipantQuote “The great advantage of running shrinkpic is all you need to do is select the image and the rest is automatic, no messing about with opening another programme.”
Just tried to install Shrinkpic and Malwarebytes has quarantined it as a nasty!
December 5, 2013 at 3:34 pm #3726 -
