Home › Forums › The Machinery Forums › Ride-on machines › Ransomes MG5 restoration
- This topic has 14 replies, 6 voices, and was last updated 11 years, 4 months ago by
ransomes256.
April 20, 2014 at 7:57 am #7605
vhgmcbuddyMemberApril 20, 2014 at 8:15 pm #7616
vhgmcbuddyMemberGood job your doing. Good to see another MG saved
May 6, 2014 at 8:55 am #7920
vhgmcbuddyMemberMay 10, 2014 at 11:49 am #7991
vhgmcbuddyMemberMay 24, 2014 at 5:56 pm #8267
vhgmcbuddyMemberMay 24, 2014 at 6:06 pm #8269
vhgmcbuddyMemberMay 25, 2014 at 11:35 am #8283
vhgmcbuddyMemberJune 9, 2014 at 5:51 pm #8592
vhgmcbuddyMemberJune 18, 2014 at 8:46 pm #8706
vhgmcbuddyMembercould anyone tell me how to check the engine oil in a mg5 crawler sturmley archer dry sump engine
thanks from DickyJune 19, 2014 at 5:25 pm #8710
ransomes256ParticipantDicky,
I have already responded to you that the MG5 is not fitted with a Sturmey Archer engine but Ransomes’s own. The SA was only fitted to the MG2.
Regards
NeilAugust 17, 2014 at 2:01 pm #9746
vhgmcbuddyMemberSomeone was asking for my machines and S/N to add to a register?? –
The machines I have are –
MG2 – 897- 1941
MG5 – 5701- 1951
MG6 – 12862- ??Tractors are located in Jedburgh in the Scottish Borders.
August 17, 2014 at 8:41 pm #9755
daveParticipantMany thanks for the no’s I will put them on the list
DaveNovember 17, 2014 at 5:03 pm #10738
vhgmcbuddyMemberfrom dicky I am restoring a mg5 no idea of age as plate has been damaged where mumber should be.I need to check the centefugal clutch first as this was not allowing gear change on engine tick over could anyone help please
November 17, 2014 at 6:02 pm #10739
vhgmcbuddyMemberDicky,
Either your engine is running far to fast on “tick over” or the clutch drum is rusty and/or clutch shoes are stuck but that’s unlikely
November 17, 2014 at 6:37 pm #10742
As identified by Rhys it is probably the speed being to fast but may also be weak clutch return springs or excessive wear in the clutch shoe pivots.
Neil -
