President plough
Home › Forums › General › Help and information › President plough
  • #28237
    farmer
    I have a 10″ two furrow plough with some linkage parts missing. I have the top link and RH adjusterble bottom link apparently complete. On the LH side I have the lower link arm and a green bracket and turning handle. I do not know what else I need. The handle turns a threaded bar. What fits on the thread? There is also a hole in this bracket. I believe a bracket goes from this fitting across to the RH frame which does have a bracket fitted. Will someone please send up photographs and dimension to enable me to finally fit the plough to the tractor. Thanks
    #28238
    farmer
    Here is a photo of my bracket. I hope that it has attached.
    Hi hope this pic helps
    Hi tried to reply over the weekend but was refused so will try now.
    I will take some more detailed photos later today, with luck! Will do some measuring as well.
    #28296
    Hi Got the photos.
    Top arm 2in hole centres from pivot to screw.
    long arm 6in centres.
