Home › Forums › The Machinery Forums › Pedestrian operated machines › Mystery SIMAR
- This topic has 36 replies, 14 voices, and was last updated 8 years, 9 months ago by
will-haggle.
April 23, 2017 at 9:18 pm #25006
vhgmcbuddyMemberWow! You weren’t kidding about being “in” the garden! Good to see you’ve rescued it and look forward to more pictures once it’s cleaned up a bit
April 24, 2017 at 7:35 am #25007
charlieKeymasterNo idea how long it was buried, possibly 40 or 50 years. I have started to clean it up, attacking the heavy rusting on the wheels with an air chisel. Restoration would be a very expensive job, as I suspect the engine internals are rusted solid due to water ingress. After cleaning I might be tempted to attempt a strip down of the machine just to see.
April 24, 2017 at 5:47 pm #25008
trusty220KeymasterI bet you’ll have it running next week! It certainly doesn’t look as bad as it first looked, and you may be surprised by the internals.
Go on, you’re dying to look!
April 24, 2017 at 6:18 pm #25009
roatavatorParticipantIf anyone can do it, Charlie can!
April 25, 2017 at 7:28 am #25016
charlieKeymasterApril 25, 2017 at 7:30 am #25019
charlieKeymasterApril 25, 2017 at 8:38 pm #25030
hortimanParticipantDo you know where it worked in Sussex Charlie ?, I guess a machine of that size would have been on a commercial nursery or a big private garden/ estate.
Not sur when Monro took over the dealership, I know my Father bought his 30 from Monro before the war.
April 26, 2017 at 7:21 am #25032
charlieKeymasterChris, the machine came from near Rotherfield. I believe Geo Monro took over in 1930 and think machine dates from the 1920’s. A 1938 advert for the 50 shows a 16 year old model 4.
April 26, 2017 at 8:27 pm #25037
hortimanParticipantI guess it was an earlier model than the type 5. Any clues to the make of the engine ?
I know there was/is a long established tree nursery close to Rotherfield, it was latterly part of the ‘Coblands group’
April 26, 2017 at 9:04 pm #25038andyfrost
ParticipantCharlie , I’m guessing it’s an early MAG engine.
April 27, 2017 at 7:34 am #25039
charlieKeymasterNo clues so far regarding make of engine, magneto or carburettor. I have now found what I assume is an engine number on the crankcase.
Thinking about what to do with this machine I may clean up one side and leave the other as found. Amazingly the large nut holding the wheel on came undone with no effort, one was almost finger loose.
Photos show engine number, axle with wheel removed and oil level sight glass on front of crankcase.April 28, 2017 at 6:11 pm #25048
vhgmcbuddyMemberLooking at it, I’d say it would be worth a bash at restoring, under the hunger it doesn’t seem anywhere near as bad as it first looked.
April 28, 2017 at 10:46 pm #25054
vhgmcbuddyMemberSorry auto correct hunger should read gunge.
April 29, 2017 at 8:28 am #25062
trusty220KeymasterLeave one side untouched?? I see what your game is- now that you’ve retired you want to take it to shows and put a sign in front saying, ” Ran out of money halfway through restoration; please give generously”
A scheme worthy of The Gnome himself. Why didn’t i think of it first?
April 29, 2017 at 8:45 am #25065
charlieKeymasterAghhhh rumbled.
