Home › Forums › General › Help and information › Monroe Tiller
- This topic has 5 replies, 3 voices, and was last updated 3 years, 8 months ago by
andyfrost.
January 4, 2023 at 3:59 pm #40402
john-e-w
ParticipantHi Guys – I have recently purchased a Mk3 MonroeTiller with a Villiers Mk15 engine and I’m attempting to refurbish it. The first thing I have to do is replace all the cables – not too much of a problem until I looked at the carburetor – Unfortunately it is missing it’s needle. Now trying to find the right carburetor and matching it to a needle is getting a little difficult. The only marking on the carb is V508C – I’m not sure if this is a type number or a casting number – whatever I can find no mention of it in the spare parts listings that I have. Most of the carburetor info I have relates to the Mk10 or Mk12 engines. The only info on the Mk15 states that “on a rotavator where the it is necessary to vary the throttle openings to suit the load, a type S12 carb is fitted”. If that is the case, does anybody know what the needle number is that I require, and more importantly where I can purchase one? It appears that the control cable is soldered directly onto the top-end of the needle – presumably there must be a nipple of some sort acting as an interface between the cable and the needle as I can’t imagine a direct solder joint between cable and needle would be acceptable.
Any help would be appreciated, otherwise I am stuck before I can start!
Regards
John E-WJanuary 4, 2023 at 6:32 pm #40403andyfrost
ParticipantGeorge at villiersparts is the man to help you out , I’m fairly certain he will have the correct needle and cable.
January 4, 2023 at 7:25 pm #40404
wristpinParticipantJanuary 5, 2023 at 10:54 am #40407john-e-w
ParticipantSorry pics should have been supplied but battery was flat on my camera – so here they are now.
Wristpin – I have the same booklet and I read it as the Mk10 & Mk12 have the AB10 or Type V. The Mk15 service manual indicates that an S12 carb is fitted to rotavators. However, thanks for your help and I will now try George at villiersparts to see what he advises – Thanks for contact Andy.Regards
John E-WJanuary 5, 2023 at 12:04 pm #40410
wristpinParticipantHow strange as my info came from two MK15 manuals. Perhaps a generation thing or a specific configuration for the Monro tiller application. I’m fairly certain that I have a diagram for an S12, for a Mk25 , I think. I’ll have a look later.
Later. Best I can find is an S10/2. If you draw a blank with George, try Jon Cruse at the Hailsham Mower Centre, he makes up cables to pattern.
January 5, 2023 at 2:06 pm #40412andyfrost
ParticipantRemember the first MK15s fitted to the Howard Bantam had the V508C carb fitted(later replaced by the S12) , so the carb you have is the correct type and fitment. Fortunately it is a very common carb , so spares are readily available.
