Monro Mk3 Tiller Help
Home › Forums › General › Help and information › Monro Mk3 Tiller Help
  • #38837
    rawdog
    Hello everyone, I have recently bought a monro mk3 tiller. The engine runs nicely but it has a problem with the clutch or drive mechanism. The machine refuses to drive or propell and stalls upon engaging gear.
    Does anyone have any advice or workshop manuals?
    I am in NZ, to my knowledge these machines aren’t very common here.
    #38838
    When the engine is running you should see the rear pto turning. With engine running when you pull on clutch lever the pto should stop. Note the series 3 Monrotiller has two levers that look like clutch levers, one is the clutch the other operates the reverse gear which is located on left hand side of gearbox towards the rear.
    A workshop manual is not available for these machines but I do have operators manual which includes illustrated parts list. I have sent you a private message with my email address, if you want a copy of the manual please send me an email.
    I also have the factory records and can date your machine from the machine number stamped on the makers plate, not the engine number.
