Look what followed me home.
Home › Forums › The Machinery Forums › Ride-on machines › Look what followed me home.
Viewing 5 posts - 16 through 20 (of 20 total)
  • #20520
    As there is effectively no mixture control on the MG2 carb I have found that the only way to get a slow enough tick over to avoid gear crunch is to play around with ignition timing by both adjusting points gap and magneto. The valve clearance also effects slow running so again have a play with the clearances. I also find that unless you run any MG crawler for about 5 minutes from starting to get it all hot then slow running and crunching are worse. Changing the clutch springs may help but shoes may make it worse.Getting it all hot and good oil in the air filter would be first on the list.
    #20521
    joegrgraham
    Thanks expeatfarmer,
    That’s some very useful advice, I’m completely new to MGs, so any advice is gratefully received.
    Joe.
    #20550
    joegrgraham
    Its now in the shed, time to start the shopping list.Can someone let me have Neil Jarrets contact details please.
    Thanks,
    Joe.
    #20551
    ransomes256
    Joe,
    email njarrett@btinternet.com
    Neil
    #20562
    joegrgraham
    Thanks Neil!
    I tried to find you, but couldn’t remember your username!.
    Joe
