Home › Forums › The Machinery Forums › Pedestrian operated machines › Kohler K141T 292287
- This topic has 2 replies, 2 voices, and was last updated 6 years, 11 months ago by
April 23, 2019 at 7:11 pm #31001
vhgmcbuddyMemberHoward 350 with the Kohler K141T engine fitted . Starts from cold OK runs, but eventually looses power, misfires bang and pops . Checked fuel and carb(Carb swapped from another engine . Wondering if the coil or condenser could be failing when hot or under load . Checked points .
Condenser is located by the coil, inside the flywheel. This is an early engine I guess as my others have the condenser mounted close to the points externally.Tried new plug, checked for kill switch wires shorting , plus checked all coil and condenser wiring . Electricall condenser seems OK as far as I can tell in as much as it works enough to start the thing . Tried running engine with the points cover removed to make sure that is not causing a short
This particular condenser is obsolete . I am thing of fitting a new condenser re locating it to the normal location near the points .
I do have an electronic ignition kit but I want to make sure the ignition system is OK before I fit it
Any ideas ?
April 23, 2019 at 8:41 pm #31003
wristpinParticipantI’ve never seen a 141 with the condenser inside the flywheel, I wonder if, for reasons unknown, a previous owner made the modification. Back to your cutting out issue. I know it sounds a bit counter intuitive but try closing the points gap down to 15/16 thou from the recommended 20. Many years ago I was nearly being driven to distraction by a 141 doing the same thing when a nice man at Meetens suggested reducing the points gap. Instant cure. That was when Meetens were at Coombe Lane, Wimbledon – a long time ago.
April 24, 2019 at 4:49 pm #31007
vhgmcbuddyMemberHi Wristpin
Thanks will close the gap a little as you suggest . It does seem more electrical than fuel . Disconnected the kill switch to count that out too.
It seems the condenser is a factory the condenser is made to fit it ! I have tried several US sites and they all say that condenser is obsolete Strange Maybe that suggests there were problems early on. This is replacement engine , as the original one failed last year I got a coil from that auction site from Guy Motors, and it seemed good even got it running then it stopped dead no spark !!! I put genuine points and condenser on the original engine too . Think I need to try and rebuild the original I popped the head off to check the valves and all seem OK . My Wife works for Kohler so may be I will see what I can do !!!
Thanks
