Home › Forums › The Main Forum Area › General talk and discussion › In-line fuel filter
- This topic has 6 replies, 4 voices, and was last updated 7 years, 5 months ago by
October 27, 2018 at 10:19 am #29489
vhgmcbuddyMemberHi All, Anyone know where I can source an in-line fuel filter with 4mm barbs for a gravity fed Villiers S10 carb? Not sure what grade filter would be best as I guess pressure fed systems can be finer meshed / harder packed but would restrict flow on a gravity one. Any help would be greatly appreciated. Cheers, Mick
October 27, 2018 at 11:48 pm #29500
wristpinParticipantRe your other “phantom post” – have you sorted the kick start issue. Probably just a stuck ratchet gear.
https://www.dropbox.com/s/uxpmk9x71kl2e01/Villiers%20kick%20start%20ratchet.doc?dl=0October 28, 2018 at 9:07 am #29504
charlieKeymasterOctober 28, 2018 at 1:44 pm #29507
vhgmcbuddyMemberHi Wristpin,
Thanks for the reply. Nothing was engaging so I took the engine off and removed the engine coupling assembly. When I took the 2 gears off (A889 A890) the grub screws in the engine coupling must have been slightly loose allowing the locking bar (R332) to slip towards the clutch assembly and the gears to spin free. All I had to do was tap the bar back, refit the parts and cramp down the grub screws nice and tight and the kick start engaged as it should. So not as big a problem as I thought if something had worn out or broken. Cheers, MickOctober 28, 2018 at 1:54 pm #29509
vhgmcbuddyMemberHi Charlie, Thanks for the reply. I’d seen there should be a gauze filter in the banjo but it was missing. Probably lost somewhere along the line by the previous owner(s) over the last 59 years and just been run without it.
Remarkably, no grot present but I thought I’d replace with an original but I can’t find one on-line (Mr Google failed on this occasion) so thought the next best option was an in-line one to prevent grot getting anywhere near the carb while I try sourcing the proper part. So still asking and still looking for something suitable for a gravity feed. Cheers, MickOctober 28, 2018 at 6:11 pm #29512andyfrost
ParticipantCharlies pic is not the gauze filter for the S10 carb , it has a much smaller one , try Paul Childs at Meetens , he should be able to sort the correct one for you.
October 29, 2018 at 9:58 am #29529
vhgmcbuddyMemberHi Andy, Thanks for the reply & advice. Will try Meetens. Cheers, Mick
