morning all i have a question on a howard gem single cyl
you have a cylinder block also a piece that houses the valves and covers
and then the head ok is there any seals that go between the block the valve holder piece and the head ,,the one i have just taken apart only has head gasket and nothing else ,,is this correct
many thanks
uncle pete
I got a set off Darmic 1 a few years back for my british junior howard gem.they are excellent quality and its been running great ever since. The original gaskets blow and are a weak spot in these machines.
morning all first thanks for the replys i had a feeling there might be ,,now can any one tell me how to contact darmic1 please as i cant see any where to message said person
thanks
pete
hi there darren
its pete james again i contacted you sometime ago regarding a howard gem rotorvator head gasket set for a british jounior engine ,,i have been very careful in looking after them as it took and age to get around to fitting them i took so good a care looking after them i cant find the darn things ,,do you still make them if so can i order a nother set if not do you know where i can get another set please
many thanks pete peter.j.james1965@gmail.com
01934834222
Author
VHGMC Forums
