Home › Forums › The Main Forum Area › Projects › Howard gem 800
- This topic has 45 replies, 12 voices, and was last updated 12 years, 1 month ago by
November 10, 2013 at 11:05 am #2740
vhgmcbuddyMemberAbout 12months ago I acquired a howard gem 800. These were produced in 1962 as an experimental prototype to replace the howard gem. The records are a little unclear but it is believed that maybe as few as 20 were produced. Over the next 2 years the machines were frequently modified so it is said that no two examples are the same. 3engine options were offered, a Sachs 600 diesel(as far as I can ascertain like the standard gem these were the only ones that came with a bonnet), a twin cylinder howard engine and a kohler k301t.
After two years Howard’s came to the conclusion that it was too expensive to produce so therefore sold off the machines cheaply.
The one which i purchased has some parts missing, including the engine, and the rear end is very rotten. But on the whole it is mostly there so will be undergoing an extensive rebuild. It was supplied to A.Turner from Haywood Heath on 21/8/1964.
Photos will follow as soon as I’m back at my main PC.November 10, 2013 at 12:55 pm #2742
vhgmcbuddyMemberNovember 10, 2013 at 12:58 pm #2746
vhgmcbuddyMemberNovember 10, 2013 at 1:01 pm #2750
vhgmcbuddyMemberNovember 10, 2013 at 1:05 pm #2755
vhgmcbuddyMemberNovember 10, 2013 at 1:10 pm #2762
vhgmcbuddyMemberThe most major component to sort out is the engine. After a lot of consideration I have decided to rebuild this machine as a Kohler example so the hunt for a doner was on. Once very plentiful now it appears that they are very hard to come by. At a local plant sale i purchased a Complete gem, however on dismantling the engine it was found to be shot!
November 10, 2013 at 1:11 pm #2765
vhgmcbuddyMemberThe engine side is on hold until I can turn up a good bottom end, hopefully one is comming my way in the new year.
November 10, 2013 at 1:14 pm #2766
vhgmcbuddyMemberNovember 10, 2013 at 1:44 pm #2769
vhgmcbuddyMemberNovember 10, 2013 at 1:47 pm #2771
vhgmcbuddyMemberNovember 10, 2013 at 1:48 pm #2773
vhgmcbuddyMemberNovember 10, 2013 at 1:51 pm #2775
vhgmcbuddyMemberNovember 10, 2013 at 1:53 pm #2778
vhgmcbuddyMemberAfter seeing examples of his work at Tractor World I bit the bullit and ordered up new i.d plates from http://www.vintagebrassplates.co.uk not cheap at £45 each but I felt it was money well spent.
November 10, 2013 at 1:55 pm #2781
vhgmcbuddyMemberNovember 10, 2013 at 4:16 pm #2804
darmic1ParticipantMaking good progress there Gareth
