Hi
Thanks for the reply, I understand there are three different areas that need to be filled with gearbox oil, in some areas the drain screws are on top so do you need to suck the oil out with a pipe and fill it up until the oil comes out of the oil level screw? Do you know how much oil I would need, would I get away with a 1l bottle?
Many Thanks for the help
Jack
