They’re not particularly difficult to change if you can change a wheelbarrow tyre. If you’re not used to changing small tyres then it’s probably more challenging.
When I’ve done it before I’ve put some scrap timber under the chassis at the engine end to support it (push down on the handles to lift up the front end, put some wood underneath and let it back down again). Do one wheel at a time and make sure you’ve got a couple of tyre levers available
