Hello. I have just acquired a Howard 300. I have little or no drive through the clutch. I have taken this apart and found a badly worn alluminium inner cone and worn steel outer. Is this how it should be, ally rubbing on steel or is there a clutch lining missing? Any help will be appreciated. Also this machine is fitted with a MAG engine. Were these used by Howard? Regards Atomical2
