Home › Forums › The Machinery Forums › Pedestrian operated machines › HELP , Ive just purchassed a Howard 700
- This topic has 71 replies, 9 voices, and was last updated 8 months, 4 weeks ago by
April 21, 2017 at 10:30 am #24991
vhgmcbuddyMemberHi, very helpful posts on here..I have just been given a Howard 700 with a Villiers 28B petrol engine which hasn’t been used for years so I too need to get it running. It has no spark so I am presuming points, condenser or coil issues. My mechanical skills are limited so would appreciate advice from members..My first issue is how to take off the flywheel ie best way to stop the engine turning to allow the flywheel nut to be released..Does taking off the flywheel effect the engine timing ? (As mentioned I’m no mechanic but willing to learn!!!)I have read the posts about spare parts which are helpful..I will need a repair manual to assist my knowledge if anyone can assist.Can anyone recommend the best agent to swill and flush the petrol tank? I will definitely need a new air filter too. Thanks in anticipation, this machine really deserves to be working again.
April 21, 2017 at 10:43 am #24992
vhgmcbuddyMemberHi If you can give me a ring we can have a chat about the 700
my number is 0 7 9 7 1 5 1 6 6 1 7All the best Jack ” myosotis “
April 21, 2017 at 10:54 am #24993
vhgmcbuddyMemberWow,quick response..Thanks Jack, will phone shortly..Mark
June 29, 2017 at 8:52 pm #25748
vhgmcbuddyMemberIve noticed this 700 has a different configuration to the one i have , it looks like the tank was re designed due to the vibration issues breaking the fixings where the tank used to connect to the head . I do know these used to break due to vibration , so did howard re design the tank or has some clever clogs modified this tank themselves ?
June 29, 2017 at 8:54 pm #25750
vhgmcbuddyMemberJune 30, 2017 at 3:38 pm #25752andyfrost
ParticipantBarry , as you say the brackets did have a habit of cracking , to overcome this Howard made the type you show in the pics , if you look closely , the tanks are slightly different in that this later type had a flare on the crease to accomodate this later modification.
June 30, 2017 at 3:45 pm #25753
vhgmcbuddyMemberHi Andy i thought that might have been the reason why , was the first one id ever seen so i thought id ask lol. See you on sunday m8.
February 12, 2018 at 6:48 pm #27907
vhgmcbuddyMemberFebruary 13, 2018 at 5:04 pm #27919
vhgmcbuddyMemberFebruary 13, 2018 at 5:09 pm #27921
vhgmcbuddyMemberMay 24, 2025 at 11:48 am #43766rub
ParticipantHi,
My name is Ruben and I’m from Spain.
I have a Howard Clifford 700 with a rotovator 20″ unit.
It belonged to my uncle and now I would like to repair.
I need diferent parts, especially from the rotavator unit.
An alternative solution, will be to buy a complet rotovator unit.
Do you know someone that can help me?
One problem, will be the transport and taxes to send the item to Spain.
That’s a matter I’ll have to cover.
I would appreciate your help.
Best regards,
Ruben
May 25, 2025 at 7:27 am #43768
charlieKeymasterRuben, could you please start a new topic for your enquiry.
