Home › Forums › The Machinery Forums › Ride-on machines › H 16hp Bolens
I have two Bolens still in use now for 40 years, one 14hXL I have re-engined with the V twin and a 11hp that has died a few times I am now thinking of re-engining that,I repaired a chainsaw for a neighbour and found out he had a H16hp Bolens thats I think been left outside some years ago, it has the flat twin Briggs, that I wouldn’t want, if still serviceable just interested in the Hydro pack, electric clutch, steering parts, its deck was shot years ago but I do have good centre discharge one that was good. hopefully going to see it will take photos, Anyone need anything,
Well done with finding the Bolens! Yes, the bent lift arm is quite interesting!
I see that the Bolens has an ‘Eliminator’ badge on the rear fender which was used in the late-1980s and in to the 1990s. The Eliminator range seems quite random and included the model 1600 and ST140 hydro; do you know what exact model this one is?
Hope the Bolens turns out to be a useful machine.
I don’t know exact model,but what could see had same hydro-axle as my other two a 1980 1058 Howard Bolens main part really good quality apart from the single Briggs engine, and a 1983-4 ish 1458 but has cheeper made bits, the Tecumseh engine was ok and economical but parts silly prices now with V twin, think will do the same with this other H 16. will go and pick it up once we have some rain to wash the salt off the roads will take a trailer and pick it up. the deck seems to be a little different, sharper edges mine looks more rounded, both my decks are good apart from righthand bearing housings as worn or corroded away one side did make a metal replacement and have a spare centre discharge I got for shafts and those bearing housings, note how they had bent the H16 lift lever, said they had oiled the knob but was hard to operate and can see why. Done some modifications to the other mowers Hydro drive and decks, since both have done nearly 30 years without being touched.
Got the H 16 home this morning its a 1668 model and serial 0501139, Its really been neglected, deck is shot looks like one bearing housing will be ok, tyres aren’t good as perished with cracks, most bits stuck, hydro-trans is very low on oil, engines oil ok but blacker than black, however steering not that worn, so will just brake it for bits and if the hydro is ok will just use that and bin the rest after have rebuilt the Howard Bolens with a V twin, so engine and framework and tin will be spare, had to take tank off to straiten the deck lift lever,
Engine runs well thats a bit of a miracle, petrol had completely gone just left sticky varnish residue, spent over 4hrs cleaning the carb, anyone want a 16hp twin could be seen running at moment while still in mower.
Few bits really usable, all deck parts, bearing housings, shafts and two pulleys are scrap,note early and late pacers so been buggered before, supposedly only used three years, well my deck in forty years use and sometimes mowed 5 acres and weekly mowed 1+ acre has needed little attention and still good. I have now modified the last front carriage to be like the early 1980 one that is easy fit and doesn’t rattle like the mark 2-3 types why on earth did they alter them, never had any issues with the first type, now its been run the hydro is started to leak so thats why it was short of oil, overheated and that heavy drive shaft got lots of runout. several photos.
A why did they do that?,
On that Eliminator model they fitted an electric brake on the hydro pedal so when you have got to a speed you want to keep at flick the switch and lock the pedal, not a safe idea in my thinking, been far better to have a variable position stop just to restrict pedal movement to a given speed and if need be would stop as normal, my daughter at only 6-7 used to mow and use a trailer as the hydro was a fail safe as soon as the pedal was released it stopped dead, with the electric braked pedal locked could just imagine the fish getting a bit of excited with a new weed cutter entering the pond or worse.
On that Eliminator model they fitted an electric brake on the hydro pedal so when you have got to a speed you want to keep at flick the switch and lock the pedal, not a safe idea in my thinking, been far better to have a variable position stop just to restrict pedal movement to a given speed and if need be would stop as normal, my daughter at only 6-7 used to mow and use a trailer as the hydro was a fail safe as soon as the pedal was released it stopped dead, with the electric braked pedal locked could just imagine the fish getting a bit of excited with a new weed cutter entering the pond or worse. and pedal sit at a silly angle very flattish adjusters look like never been touched, very odd.
Well not going to repair the Eliminator, my old Howard Bolens is in much better not been got at condition yesterday got a USA made V twin, but takes a day building it up, also the old Howard drive shaft is different to the later 14 HXLin that the copling has a 1” inch drive two piece where as the older one is a single piece and bolts strait onto the flywheel, so will copy the later one. just been given some bits looks like three bering housings and bearings with a good belt tensioning pulley still shiny.
Does any UK firm supply a Hydro seal kit. I have all the nessarsery plain bearings left over from the last one I did. I had forgotten just how many O rings and teflon seals there were in a kit. photo of what had to replace last one I had to do. I tried to building up the damaged squash plate but wasn’t hard enough and the hyro clamps just beaded in, made one out of a heavy duty cultivator leg.
Is the hydro Bolens own or a proprietary lump?
No, think its a Eaton, smaller versions are fitted in the Westwood, JD and others. running out of line with the Briggs flat twin and with the heavy prop shaft has knocked out the plain bearings, I was hoping the Eliminator would yield some useful bits but is shot everywhere, just taken the early 11hp out of the Howard Bolens,I rebuilt that 20 something years ago and as hole unit never been neglected going to rebuild that, just odd the 11hp has a 1” 1/8 output shaft flywheel end the new V twin has an 1”inch. When I done the 14hp and fitted the V twin in that that shaft coupling was same as the Tecumseh so a lot easier swap.
