Home › Forums › General › Help and information › Ex Air ministry Alcon Pumps
These were bought sometime in the 1950s, ex air ministry. One was seized and was only used for spares. The other one also came crated with a multitude of spare parts, this was used for years and we never realised the differences between to the two pumps.
The one Jap engine has no governors and internally the valves only have the normal single guide, the cam shaft has large gear teeth. It also had screened ignition with what looked like and aircraft plug in. This was difficult to get but this was replaced with a normal plug lead and plug.
The other engine had governors and the valves were supported in two guides, which is unusual. The normal guide at the top and another below the spring. The cam shaft had fine gear teeth.
The one without governors revd upto 4000 which way above the 2400 that the manufacturers said. It also fast primed which is probably why.
With me being inquisitive as a young boy. I pulled the spare pump apart, but it then got pushed into an empty bath for 40 some years in bit. In the end for something to do I got it out, reassembled and it actually goes.
Does anyone know what the differences in years are and also why they had these differences.
I’ve worked on quite a number of 2As , and have seen both types of camshaft , but have NEVER seen one without govenors , out of interest is the block machined to take the govenor shaft. I can’t envisage a 2A lasting very long at 4000RPM…… something doesn’t seem to add up here.
The one on the right that did have governors just has the one small brass plug carburettor side, I found you had to hold the governors open to be able to prime in a reasonable time and when it did the governors just opened the carb to full throttle so they were of really no use so did away with them. However the engine started to knock in only two hours of use, the white metal in the big end shell had just been squeezed out and it looked as it was very soft. The other engine been running ok for around thirty years and never had a issue, took a good look at the carbs they were slightly different the un-governed the butterfly only partially opens so it got the revs to prime but reckon it restricts full constant overload, so I welded a bit on the butterfly rods arm to stop full throttle and ran them side by side so got same revs under load. I also noticed the spare shell sets look a very white colour where the failed shell was dark grey and just thought they had deteriorated laying about all that time. Now the un-governed block is very different in several places, instead of the one small brass plug for the governor rod carb side its got one large ether side and casting bumps filler cap side looks like other attachments for working the governors if it had any. The crankshafts the same as the one that was in use filled its sump with water and found that the metal had rotted away where the seal sat so swapping them was a quick fix, later skimmed a bit off the crank and slid a bit of stainless pipe over and further mods to take a modern seal wasn’t that easy, the old type was just a very thick carbon washer with a bit of rubber held tight against it by a spring still watertight in nearly 80 years. They are particular painful to start with the small rope pulley and light in weight both had there oil filler caps shared off as they lept up the pull-start rope and fell on there caps. was told were probably ment to run on the 100 octane so higher compression?.
Sorry David I can’t make alot of sense with that , there’s no way a 2A would rev to 4000 , it would simply blow up after VERY short time.Assuming you had both engines stripped out , did the ungoverned one have any sign of the internal govenor components.When correct they are one of the easiest starting engines , I’ve just finished one on a Howard Bulldog for a friend , starts first pull and runs like a clock.
Yes they are very easy starting but these two really do take some bit to get over compression and best way is to turn them over by hand until at TDC then rap the rope and go for it, if you don’t they bite back, There was nothing of any governors on the one.
One was running last year when it was getting dry so just incase soaked round my bonfire, the other hasn’t for some years used to hook up both together to get a bit more pressure.
and yes the book says not to operate above 2,400 RPM well the one been doing over that for over fifty years. I’ll see if my daughter can do a video.
Hi David,
Have a 1½” Alcon pump powered by the Villiers engine. Got it in the 1980’s and used it for irrigation. But then got sprinker rotor heads that needed a higher pressure (30 – 35 psi) than my original ones. The pump also started to take an age to prime. Fitted a new seal kit I got from Vulcan Water Pump Seals, it improved the suction, but still the pressure was not sufficient. Got another Honda engined Clark pump (26 meter head), but still the pressure was not enough. So did try to link the two together, but I only got a small increase in pressure. In the end got a Robin engine Koshin pump (30+ meter head), it performed well.
Took the Alcon pump apart again and found the engine crankshaft was pitted with rust. I think these indents allow a small amount of air to get past the seal and effect the pump’s performance. I was going to go along a similar line to yourself and sleeve the crankshaft. But without your skills I was going to use a hardened stainless steel shaft repair sleeve. Proposed to fit it over the shaft then grind off the flange. What do you think of that idea.
Decided I would swap the Koshin pump and fit it on the nearly new Honda engine, the Clark pump onto the well used Robin engine. Found that the crankshaft on the Robin engine had grooves on it where the seal was in contact with it. Also the Clark pump seal was not in the best condition, so replaced it with one from Vulcan. Now have two pumps that perform well, although the Koshin is the superior one.
Dropped on some Evenshower Oscillating Spraylines and these operate at a much reduced pressure. In fact I now use the Clark pump and only need half revs from the Robin engine. The original pendulum operated oscillation valve was worn out and leaked everywhere. So make another from a pair of ¼” ballvalves. But the operation was too stiff for the pendulum, freeing them up caused leaks. Have just spent Easter Sunday making a new valve with a 3 port L configuration. Have high hopes of success and will be starting irrigation this week. It needs it too, in my part of the world near Evesham we have not have any significant rain for 6 weeks or more. Am going to put a pressure gauge on the irrigation system to see exactly what pressure the spraylines need. They are very satisfying to see operating, gently and quietly going from one side to the other in true 1950 – 60’s market gardening style.
Best wishes,
Grahame
The Villiers engined pumps were the 2” inch JAP’s 1.5 inch and I just had a bit of seamed stainless pipe, don’t think the engine shaft was more than 4 inches, so a reamer took the bumps out, the new ceramic seal worked similar to the very simple carbon disc, bit of rubber with a spring to push those bit up against the brass bit the pump body, it wore very little over all those years, its amazing it often would instant pump after standing overnight without the water running back so the clack valve done its job, in the very dry times it help water the stock maybe a field away from the farm it often lived out for a month or so just with a old tin bath hung over drawing water from a pond. It once ran a week every day flat out emptying fire lagoons on a airfield as they were being taken out. and the one pump has a pressure gauge on it and rarely did it better the red line of twenty.
Hi David,
My Villiers engined Alcon pump is definitely 1½”. It does have a model number on it. I got it from a retiring market gardener, who sold me all the delivery and suction hoses too. It ran poorly, so I did my usual top end, points and carb service, it then ran well. It was noisy though under load and drank fuel. The Honda GX160 is a lot quieter and less thirsty, the Robin EY15 even better on both counts. The pumps have a superior performance than the Alcon too. So am on no particular rush to get the Villiers/Alcon combi running again. Very interested to hear that the pressure gauge had a red line at 20 psi and it rarely achieved that. It explains a lot. A friend of mine got 16 spraylines (they are each 15’ long) with a Villiers/Alcon combi and it never worked very well. He said he then got a Honda pump that ran the spraylines fine. He grew lettuce, watering regularly. He filled the fuel tank full and left it to run dry whilst he went off to do another job.
When I first took the Alcon pump apart, found the seal had all but disintegrated. Vulcan Water Seals were very helpful in identifying a replacement and were keen for it to be added to their database. The Clark pump had been purchased by a chap who had had his house flooded and wanted it in case it happened again. He then moved house and had no further use for it. He started the engine every few months, but did not know he was meant to put a bit of water in it to keep the seal lubricated. When I came to swap the pumps over I could see the damage done, so put a new seal in, again from Vulcan. Just for the fun of it I tested the suction with a vacuum gauge. This is when I found the Alcon pump was not achieving the recommended 20-25 ins Hg negative pressure. The others passed.
Had an idea to increase pressure by pumping from one pump, through another to replicate a multistage pump. But it did not work, the second pump was the Alcon and the Villiers engine struggled with the flow rate from the Clark pump. I did get an increase in pressure, but it was not enough. Quickly realized a multistage pump needs to have a calibrated flow from the first stage to the second and maybe a different impeller design too. My effort was doomed to failure.
Best wishes,
Grahame
An update the Alcon 1½” pump. Went to an auction on Wednesday, there were two pumps there in one lot. One attached to a JAP 2a, the other to a 3 phase electric motor. The latter had an embossed ali label on it stating the pump had a head of 66’, so around 20m. This compares very poorly to even the cheapest Chinese modern equivalents if it is to be used for an irrigation system with even a medium pressure requirement. Am assuming the pump had a market for lower pressure irrigation systems and simple water transfer use with the smaller horsepower engines that were available.
The auctioneer had to drop the bid to £10 to get going, still no hands up until muggings put his up and won it. It’s worth it in scrap alone because of the heavy electric motor. But the JAP pump set is very tidy, as is the electric set up. The JAP set is painted lime green and was wondering if anyone has seen this colour before. Am not sure if it’s factory applied paint by Alcon, or someone has done it when it had a reconditioning. Both the Villiers engine pump and the electric one has the usual dark green paint that I have seen on other Alcon pumps. Whatever, it looks very clean, but without any compression. A stuck valve is suspected. Will have a play when I have some spare time and see if I can get it going.
Grshame, daughter has done a video of the two Alcons today it might be a time before i see how it came out, I can tell how long the one pump was in work to as stamped date in 2002 as that was when I resurrected the donor parts pump back into working order and used that, So stood twenty two years. Bit disappointed as had to give it two pulls before it fired up, flat out that you say they can’t run long like that and that now frightens me a bit but been doing that for now 70? years and still hanging in there. I then started the other engine and they take 5-10 minutes to prime so both had ben making some bit of noise and noticed I hadn’t dropped the old faithfuls hose into the water, so no wonder it was a bit more noisy, dumped the hose into the pond and it only took seconds it seemed and was primed so that is quick, but once up and running there’s no difference, think running just under 20 psi and doubled up more or less double the pressure. Just as I had nearly cleared up the friend that had put his rev counter on that old engine 50 years ago came over and he remembered the 4000 rpm. Both engines differ with the well used engine having a serial number ending in 40? date, and other has nothing, both were in the AM green the resurrected one still is what paint still there. just recently was give a few Jap bits and looks like was from a generator going by the head, tin cowl good no dents and sump, and if you find the loss of compression isn’t just a stuck valve and was a cam-follower I have a spare so all free to anyone.
If any bit of equipment is not going to be used in the next few months I get the fuel out and if its a steel tank suck it completely dry, spray bit of oil in helps and same with the water side but you must not get oil near any part of the rubber seal. Just after the much used Alcon primed and with two engines running didn’t twig which of one of them made for a split second a funny noise, at the time I was striating the hose out as they knuckle and stop the water but now looking back can see why water slowed and went, I recon it was a hand full of hazel nuts the mice had carried into the suction pipe as the jet of water slowed but hose was still hard with pressure, had to knock out one hole nut out and found it in the bottom of the trailer while laying the pumps up. I have repaired a few pump housings caused by objects getting sucked up the suction pipe, one time found wedged in but not got in to do damage was a petrol lighter.
Hi David,
Took a couple of pictures of the one I got at the auction. Also my old original Villiers pump to add context. The JAP pump has a nameplate on the cowling with the first number being 1943. Do not know if that is the date it was put together, or if it is a coincidence. Also do not know if Alcon purchased the engines unpainted, then painted them all over in one colour. Or if it was reconditioned at some point and it was then it received the lime green finish. Be good it anyone could shed more light on this. The most important thing though is to get it working again and from the time it was painted, do not think it’s done much work. The oil is clean and the lot number shown is from a different auction. So it was likely purchased then, either the just stored, or the new owner could not get it to go until the farm clearance sale when I got it.
Had to do a bit of research about pumps when the Villiers engined Alcon pump would not provide enough pressure after I purchased 7off Hunter MP2000 Rotators to replace rotaframes. It would not both atomize the water sufficiently and throw it to the radius specified. I needed 25psi minimum, ideally 40psi, but 30psi would be OK at flow rates of 6.1, 7.7 or 6.7 gallons per minute respectively. Not many small petrol pumps could do that. But then got a Honda pump that just about did the job. During this research I discovered that you need a minimum negative pressure of 20 ins Hg (25” is optimal) on the suction side. Got a negative pressure gauge and did some testing and it was then I could determine if a seal needed replacing. Am afraid the Alcon pump never achieved the minimum negative suction pressure, even with a new seal. I also found that a new Clark 2” pump that had been run without water in it many times had ruined it’s seal too. A quick test is to put the palm of your hand over the suction end and it should have sufficient pull to feel quite painful. Or the time it takes to start pumping and if yours does this so quick, the seals are good. The Villiers pump used to take 3+ minutes.
If my Alcon pump was in good condition and could produce 66ft head, this would equate to 28psi with very little flow. Obviously pressure reduces as the flow rate increases. Another problem I had with the Rotators was blockages to the nozzles, so had to get a filter. Am pumping from a well into 80m of layflat tubing and found even tiny bits of debris (mainly little seeds and slime) caused troubles. Such a system really needs a permanently fixed suction pipe and underground delivery pipes. I then acquired an Evenshower Oscillating Sprayline system and upgraded it by doubling the nozzles to 10off on 6 sections and replacing the original worn out cone type 3 port valve to a ¼” BSP ball 3 port L valve. It works really well. It only needs 12 – 15psi at 7GPM. Believe it will run on a recently acquired 1” Locin pump, or a 1½” Alcon pump. But I now run it with the Clark 2” pump hooked up to a Robin EY15 engine and after it has started to delivery water from the well. Reduce the revs to about a third. It then purrs along under little stress. It’s a stress reliever for me too, I find watching, smelling and listening to an irrigation system operating therapeutic.
Best wishes,
Grahame
Grahame
Both pumps seals might be ok, the old faithful has the just rubber washer and carbon ring running on a brass bush and is very quick to prime other has real good suction but takes ages to do so, the others carbon bush was robbed so thats got modern Alcon seal ceramic buts looks more to fail, never seen more than just over 20psi with those jets and with the two was putting out around 40, there is very little corrosion in the old faithful although in regular use and hardly ever dry, but the other is very badly pitted as stood years before I took it apart in the 60s so might have pumped something bit corrosive, engine is more or less in unused condition, All fittings have AM and crown and seem to remember same on the pumps but can’t find those, It would even rev higher I think as butterfly is only partly open. https://youtu.be/lMhDYL2Z_ag
Hi David,
Fantastic video. The seal I took out of the Villiers/Alcon pump was all covered in crud and breaking up. Vulcan Seals asked if I could send it to them so a replacement could be identified and also they would have a record of it on their database. Just looked it up and it was in 2011 when I got the new seal. I cannot recall what the old seal’s construction method was. But they said the one I sent was probably a John Crane type from around the 1980’s, so not the original seal. The ungovened pump certainly revs away, a testament to the quality of JAP’s, which I think are better engines than Villiers. Believe this is from their heritage of high performance engines.
Noted the increase in pressure when you hooked up both pumps. When I tried it, it only raised the pressure by about 20%. What I did was pump from a more powerful Honda/Clark pump through the Villiers/Alcon set. The Villiers had a duff seal at the time and even if it would have been a good one. Think the difference in pump design and specification would have caused a degree of conflict within the system. It may have worked better if the Villiers pump supplied the Honda and that would have boosted the pressure more.
Vulcan Seals were very helpful in identifying a replacement seal for both the Alcon and Clark pumps. Leaks through the impeller shaft is very common, with wear damage and corrosion to the shaft being the problem. They have bellows type seals that help to overcome this and it is that what I fitted to the Alcon pump. But the corrosion over the length of the shaft I think meant it did not fully seal. I was going to get a stainless steel shaft repair sleeve to fix it. But it’s way down on my list of priorities because even if it performs as it should. It will still be not as good as more modern pumps. The Villiers engine is a good one, but is more thirsty and noisy than the Honda and Robin engines, the Alcon pump delivers a lower pressure. Did note that every pump I took apart had a degree of damage to the steel drive shaft. It was one of the reasons I swapped the engines over as the seals were then in contact with the shaft at a different position. If the stationary and rotary faces of the seal starts to create a lot of friction. It can partially seize and then the drive element will then start to turn on the shaft, causing damage, wear and finally a leak. It’s why a pump should never run with no water in it. Also pumping dirty water will wear the seal contact faces out quickly as well as scoring them. This roughens it and can lead to the surfaces gripping, again causing the seal to rotate on the shaft. An old boy who once installed irrigation systems for Evenproducts told me that even a tiny leak on the suction side significantly affects pump performance. It can cause cavitation and he has seen damage to the aluminium surfaces within a pump from it. Think some of the trouble with seals is also caused if there is a steel shaft that then rusts over time. The Villiers engine’s shaft was very pitted and although I sanded the rust off, think the amount of material removed and the still rough surface. Has enabled a small amount of air to get through. I do drain my pumps after each use, but when storing them now am going to blow them through as well. Great advice and thank you.
In summary, the Villiers/Alcon set had a well seized drain plug, I think water was left in it permanently, causing the engine shaft to rust. The Honda/Clark pump was brand new, got in case of flooding and started every couple of months, running dry. The sealing surfaces gripped, causing the seal drive to turn on the engine shaft. The Robin/Koshin (it was a Koshin SE-50X pump I got for the higher pressure, it’s was not a Honda pump as previously stated) was from a plant hire fleet and had a hard life with a strong possibility of being used for dirty water. The seal was very worn, with evidence of the drive element turning on the shaft. All of the above could have been prevented with better user understanding and care of the equipment. Hope my experiences will help others in the use of pumps. It’s all worked out very well for me because I purchased broken pumps cheap, repaired them at little cost and have some cracking kit now. Was enjoyable learning about them too. Makes me think I must have been soft in the head when I put my hand up at last week’s auction. It was in part because of your descriptions of your pumps was at the back of mind when there were no bidders. Seeing your video has given me impetus to get the new acquisition going again.
Did some watering yesterday evening and took some (not very good) pictures of the Evenproducts Oscillating Sprayline. In the Vale of Evesham when I was growing up most market gardeners had this setup. You do not see them now as traditional market gardening has died out. The oscillating system is really simple, with the tank filling from a nozzle and as it gets heaver it moves downwards against the effect of the counter-weight, twisting the sprayline (anti-clockwise in the photo). When the tank is near the ground the pendulum swings (to the left in the photo), the water from the nozzle is stopped by the 3 port valve and the water in the tank slowly drains out through the valve, the falling counter-weight twisting the sprayline in the opposite direction (clockwise in the photo). When to tank is nearly empty and raised up, the pendulum moves again, the tank starts to fill and the cycle starts over again. You can adjust flow rates and the pendulum stops for oscillation speed and irrigated width. The downsides are they are more labour intensive to move around, the irrigated area is small and precipitation rates low. None of this is a bother to me though, because it has upsides too. It is quiet, the application more even than sprinkers and they are better suited to pumping from a well with a limited volume.
Best wishes,
Grahame
David/Grahame , it may be worth getting in touch with Panks in Norwich , they used to be Alcon agents , pumps of all types was their speciality. My Father bought a brand new Villiers/Alcon unit from them when I was a youngster.
I know neither of you will agree , but the Alcon type pumps are not meant to be used for pressure applications , my Father used his commercial sprinkler system driven by a large Godwin piston pump , which we drove using his Petter Atomic diesel , it would operate four commercial sized guns with ease. The Alcon was only used for what it was designed for , just transferring water to large holding tanks for Greenhouse work.
No mention has been made of the use of footvalves???.
