Home › Forums › The Machinery Forums › Ride-on machines › Bean Rowcrop Tractor
- This topic has 10 replies, 5 voices, and was last updated 12 years ago by
franktonpaget.
January 22, 2014 at 9:24 pm #5367
vhgmcbuddyMemberDoes anyone please have one of these machines? I hope to begin restoration of one fitted with a Ford sidevalve engine soon and would be glad to have any advice re the job and/or any clues as to where user manual, advertising material, photos etc may be found.
Many thanks
David
Megandlottie@gmail.comThe photo is not mine but a superbly-restored example of a Bean!
January 24, 2014 at 8:11 pm #5411
vhgmcbuddyMemberThere is a Bean being exhibited at the Somerset Tractor Show Bath and West showground
on 1st and 2nd February. Worth a look if you live nearby.January 25, 2014 at 8:18 am #5433
charlieKeymasterThe one at the show mentioned could well be one of several owned by one of our club members.
January 26, 2014 at 11:17 pm #5500
vhgmcbuddyMemberThanks for the ref to Shepton Mallet next week.
This old girl is not seized but needs rebuild. V appreciative of any clues re. spares, manual etc.
No idea why it is green.
Another modification is the drive wheels; the frame has been cut and widened, wheel spacers fixed to drums and wheel dishes reversed.
Previous owner says it was to enable wider rows to be cultivated.
There is no spec plate to be seen anywhere. Can anyone guess its age?
Cheers!February 19, 2014 at 10:10 pm #5922franktonpaget
ParticipantThe Bean used a Ford 8hp sidevalve engine with the 10cwt Ford van axle
I have a Ford engine dating record if you can give me the engine number stamped on the angled surface above the exhaust manifold I can give you a manufacturing year for the engine and approximate month of production,which if the engine is original should give some guide to age of machine.
Your machine looks to be a three wheeler which was the original design dating from 1940’s, I have a early price list dated May 1946 and the introduction by Humberside Agricultural Products Co Ltd of a new horticultural tractor was announced in Farm Implement and Machinery Review in April 1945.
All Bean’s I have seen have been painted red with implements painted green
Hope this assists, will try and add some illustrations
regards Joe PagetFebruary 19, 2014 at 10:52 pm #5929
vhgmcbuddyMemberGood evening, Joe,
Many thanks for this email, which is the best information I’ve seen so far! The article is fascinating and the technical data is excellent.
Good evening, Joe,I’ve just come in from the garage, where I’m fettling up a replacement engine which is stated to be low mileage; the original is in need of a rebuild.
The colour was originally red and it has been modified somewhat but that is all part of its charm. The aim is not to over-retsore it but to get into weather-proof running order …. another way of saying I’m a garden-shed mechanic, definitely not an engineer!
Your offer to date the engine is much-appreciated and I will send both soon.
Kind regards
David
February 20, 2014 at 9:35 am #5933
vhgmcbuddyMemberThanks for the update re handbook .. I have a printer and would be v glad of a copy.
DavidFebruary 20, 2014 at 10:20 am #5935
will-haggleParticipantFebruary 20, 2014 at 10:07 pm #5946
vhgmcbuddyMemberHi again, Joe,
I checked the engine number on the original block; it is a bit unclear looks like
RY 1357101(0?)1P
The replacement is
RY1091356PC
V Grateful if you can date them.
Regards
David
February 20, 2014 at 10:09 pm #5947
vhgmcbuddyMemberDear Alan,
many thanks for the photos … Excellent clues for the rebuild!
Kind regards
David
February 21, 2014 at 9:38 am #5952franktonpaget
ParticipantDavid,
8hp engines serial numbers start with “Y” followed by six numbers.
The numbers you supplied are RY135710(0)IP and RY1091356PC
You have too many numbers ?
If it was RY135710, this would be a reconditioned engine (R) Y for 8hp and 135710 was manufactured in 1936
If it was RY109135,, this would be a reconditioned engine (R) Y for 8hp and 109135 was manufactured in 1935
The one thing for sure is you have two Ford reconditioned engines , so these engines are not original to your tractor and will not help with dating
Another route is to have a look at the Lucas dynamo and starter,Lucas stamped year of manufacture on the body casing if they are originals and hopefully the same year this might give you a manufacturing year.Anyway worth a try
regards Joe Paget -
