Home › Forums › General › Help and information › Atco Ride-On Lawnmower
- This topic has 14 replies, 7 voices, and was last updated 4 years, 8 months ago by
richfinn42.
January 15, 2022 at 12:39 pm #38438
richfinn42
ParticipantCan anyone help with a manufacturing date for an ATCO ride-on lawnmower model 28L by Charles H Pugh? it has a kick start Villiers four stoke engine with a flywheel magneto and aluminium rollers and has a Brookes leather saddle for a seat.
January 15, 2022 at 9:15 pm #38446
vhgmcbuddyKeymasterHi
Please add a photo of your machine, it always helps when identifying it
Regards
AndrewJanuary 15, 2022 at 10:37 pm #38447
wristpinParticipantPlease add a photo of your machine, it always helps when identifying it
Hear, hear! Why are so many looking for help but reluctant to make it easier to give it. Always the possibility that the seat belongs to a different make of mower.
January 16, 2022 at 7:48 am #38448
charlieKeymasterIt sounds like a normal ATCO motor mower with ride on/trailed seat rather than a true ride on mower.
January 16, 2022 at 8:59 am #38451ted20
Participantthe possible reason some members ( like myself ) find it too difficult or time consuming to clart on shrinking photos other sites I use CAN use full size photos not everyone is a nerd with a computer
January 16, 2022 at 12:34 pm #38455
wristpinParticipantthe possible reason some members ( like myself ) find it too difficult or time consuming to clart on shrinking photos other sites I use CAN use full size photos not everyone is a nerd with a computer
With respect, if the questioner finds it too time consuming to supply the clues, why should he/she expect others to β consume their timeβ trying to assist?
January 17, 2022 at 8:03 am #38456
charlieKeymasterThere is a reason for limiting photo file size; server storage capacity and the subsequent cost of having more, which would have to be paid for. Larger files will also take longer to upload and open when viewed.
There is a guide to reducing photo file size in the Help and Information section of the forum at https://vhgmc.co.uk/forums/topic/compressing-photo-files-using-ms-office-picture-manager/
It is a very simple operation.January 17, 2022 at 10:19 am #38458
alanKeymasterRe photos size, I’ll add that using the in-built Snipping Tool in Windows is a good way to reduce the data size of photos. It can be found by searching for Snipping Tool through the Windows start menu. Once the cursor has been dragged around the photo or relevant area that you want, then it can be saved with a suitable filename.
January 19, 2022 at 10:01 am #38472richfinn42
ParticipantJanuary 20, 2022 at 10:48 pm #38474
Thanks for sharing the picture, although small (its amazing what a large magnifying glass can do)
Your model on that frame started life in 1948, then the engine would have been a 147 cc Atco-Villiers two stroke.
Yours is later, the first year they put your style engine on the 28 inch was 1960.Your engine by the way is an Atco-Villiers Mk 25, 4 stroke, cooled by fan and cowl. The carb if original should be Atco-Villiers, Single lever control. Fitted with air strangler for assisting engine starting when cold.
Looking at your petrol tank, that shape is post 1964, pre 1964 the tank had round, domed ends, so if the tank is original to the mower its then post 1964.
Your machine should have a square plate attached to this side, where the top hanger is for the grass box, I cannot see it from your picture, but if there, I should be able to date the frame from the numbers stamped on it.
Your roller seat appears correct, except for the actual seat, the brooks is wrong, it should be a pressed steel seat, which might be a little more comfortable around the nether regions when going over uneven ground! The Brooks would be better placed back on the cycle it came off!
Hope this has helped
Regards AndrewJanuary 20, 2022 at 11:12 pm #38475
vhgmcbuddyKeymasterJanuary 20, 2022 at 11:49 pm #38481
wristpinParticipantI was holding back with a query in the hope that someone with more knowledge would ask the same question or supply the answer.
The OP describes the machine as an L28. I assume that the 28 refers to the width of cut but all my parts books, albeit for Mk25 engined machines, use the L for 34β machines and a J for 28β machines. The Brooks (with no E) saddle was not the sole preserve of motor cycles; the early belt driven Webb 24s with the Villiers 150cc Lightweight engine were fitted with them as original equipment – my father-in-law had one – and I believe that the Anzani Powermow also used a Brooks.January 21, 2022 at 9:12 am #38482
vhgmcbuddyKeymasterHi Angus
I think you will find the original seat for the Webb 24 inch was by Terry, but you are correct on Anzani
Best Wishes
AndrewJanuary 21, 2022 at 12:56 pm #38483andyfrost
ParticipantIncase you’re concerned over engine spares , your engine is standard Villiers the carb is a little more obscure , but parts are readily avilable , as are all other engine internals , gaskets etc.
The Mk25 is a very common engine , fitted to countless horticultural/industrial equipment , and had no ties to Atco , other than they were just another customer.Andy.
January 22, 2022 at 10:31 am #38487richfinn42
ParticipantMany thanks one and all for your information, much appreciated.
Richard
